Need Additional Lighting, Where Should/can I Add It? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-03-2013, 07:25 AM   #1
Rewards Points: 384
Need additional lighting, where should/can I add it?
The kitchen had soffits that were removed, they had recessed lights in them and even though we added the cabinet lighting it still seems dark at night. It's nice but if we want to read at the island it's dark. We were thinking of adding a better light to the ceiling fan but I think those lights are ugly and I just want a ceiling fan there plus the fan isn't centered on the island so a light will be out of place too.
Here are options that I've thought of so far. The easier the better since there is not easy access to the space above so running wire is a pain.
1. Move the ceiling fan over and put two recessed lights next to it. This would allow me to easily center the fan since I could put a light where the current box is and then just string it along. Not sure about the light and the fan, would it "flicker" if the fan was below the lights?
2. Along the left wall try to put 2-3 recessed lights up there about 1' away from the wall.
Need additional lighting, where should/can I add it?-2013-11-03-08.04.25.jpg
RyanD is offline   Reply With Quote
Old 11-03-2013, 07:42 AM   #2
PoleCat's Avatar
Rewards Points: 1,646
Interior design is one of the subjects I am most likely to epic fail in so with that in mind......I would go with some spiffy looking sconce lights along that left wall set at a height that would optimize the bounce of light off the white ceiling down to the desired location.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 11-03-2013, 08:01 AM   #3
MarginallyQualified
Rewards Points: 2,464
That calls for task lighting or a LOT of general lighting.
Start with brighter bulbs (and maybe dimmers)...
in the light fixtures you already have there.
See how many watts/lumens YOU require.
Old 11-03-2013, 08:51 AM   #4
Rewards Points: 236
i say = search for a fan light that you like.
Fix'n it is offline   Reply With Quote
Old 11-03-2013, 08:57 AM   #5
In a little over my head
Rewards Points: 706
Track lights or more of the pendants.
ratherbefishing is offline   Reply With Quote
Old 11-03-2013, 11:39 AM   #6
Bill Kearney
Rewards Points: 1,174
Don't put he fan where it'll cause the lights to strobe, that's really annoying. I mean, it'd beat having 'no light' but not by much.
I'd vote for better pendant lighting over the island.
Running wire might be 'a pain' but so's living with lighting that doesn't work.
More often than not, drywall patches and paints a lot faster than fighting with wiring...
wkearney99 is offline   Reply With Quote
Old 11-03-2013, 04:16 PM   #7
Rewards Points: 5,974
I gotta go with the pendants.
Solar Landscape Lighting - Any generate REAL light? 99altrade Landscaping & Lawn Care 4 08-02-2011 12:15 PM
Need to fix line voltage outdoor lighting noone Electrical 5 05-19-2011 11:49 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
General design and lighting? mrs1885 Landscaping & Lawn Care 14 01-06-2011 03:12 PM
Linking the 5amp lighting live to the 13amp neutral causes tripping of the rcb. Why? StevieV Electrical 8 08-24-2008 09:42 PM
