Need To Add Buried Downspout Drain With Patio - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-07-2011, 05:17 PM   #1
Need to add buried downspout drain with patio
I will be burying a drain and tying t downspouts off of garage and running to storm drain.
This is not a problem.
My question is can I tie in a floor drain from the patio as well?
Or will I have back flow issue?
Maybe add foot valve/Back flow preventer?
bjlffire is offline   Reply With Quote
Old 09-08-2011, 07:33 AM   #2
Patios don't normally have drains, they are supposed to slope to drain water. But the quick answer is yes, if it all runs downhill. Just wondering how you make connections under a concrete slab??? I assume the patio drain does not connect to the house sewer line???
Old 09-08-2011, 07:44 AM   #3
biggles's Avatar
see if you can install a TEE-Y for the patio connection on the run out to the storm drain but as said as long as its pitched it should all flow besides the roof is the major drain off the patio won't catch as much rain...
Patio Cracked & Sinking silvabul Building & Construction 3 05-04-2011 10:53 AM
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 6 02-15-2010 11:24 AM
relocating washer drain idodishez Plumbing 7 04-21-2009 09:36 PM
Condensor drain Captflx HVAC 6 08-17-2008 11:19 AM
sewer backup and stench jayhill Plumbing 12 08-14-2008 12:06 AM
