Natural Gas Odor In House - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-28-2011, 10:22 AM   #1
Superswid's Avatar
Natural Gas Odor in House
Hello, we started noticing that our house has a natural gas odor, especially in one corner of our house. At first, we noticed it before we bought the house, when we would come to look at it. The gas co was called out twice and checked everything out thoroughly, and no leaks were detected. The smell went away but now, it comes back, curiously, only whenever we open all the windows and air flows into/out of the house. When everything is shut, no smell whatsoever. When we walk outside, we don't smell it so the odor isn't coming from outside. We're baffled because we've done everything we can do to make sure there isn't any gas leaks. Does anyone have any clue as to what this might be and why we only smell it when we open the windows?
Superswid is offline   Reply With Quote
Old 11-28-2011, 10:50 AM   #2
Rewards Points: 2,238
When the gas company came out did they use a "sensor"?
You could have "methane" gas coming from your plumbing!
rossfingal
rossfingal is offline   Reply With Quote
Old 11-28-2011, 11:25 AM   #3
Rewards Points: 502
my guess is you are smelling sewer gas.
forresth is offline   Reply With Quote
Old 11-28-2011, 11:57 AM   #4
joed's Avatar
Rewards Points: 12,018
Did they check outside when they came? How close is the window to the meter? Could be an issue with a leaking meter.
Call them again.
Old 11-28-2011, 12:33 PM   #5
Superswid's Avatar
The gas co checked inside and outside, including the meter and no leaks. they used a couple of different devices to check.
If it is sewer related, how would I diagnose this and what do you do to fix the issue?
Old 11-28-2011, 01:07 PM   #6
Rewards Points: 5,336
If the house has not been lived in for awhile, the plumbing traps dry out and as forresth said, sewer gases get into the house.
Go around and flush all the toilets and run all the showers, tubs and sinks. If the washing machine has a trap, fill fill the drain with a few cups of water.
Ron
B. Franklin 1759
Old 11-28-2011, 02:01 PM   #7
Superswid's Avatar
I'll give that a try. The house hadn't been lived in for a while so that sounds like it might be the issue. We've been there for a month, but haven't used all of the toilets/showers since it's just me and my wife. About how long of a duration would you say we should run the showers/sinks and flush toilets that we don't typically use in order to affect the situation?
Old 11-28-2011, 02:41 PM   #8
The sink traps seal with a pint of water. Turn the water on and count to 5. The toilet with one flush.
Ron
B. Franklin 1759
Old 11-28-2011, 02:46 PM   #9
Rewards Points: 56
And a half gallon or so in floor drains, if you have any in a slab or basement.
The Following User Says Thank You to DexterII For This Useful Post:
Ron6519 (11-28-2011)
Old 11-28-2011, 03:08 PM   #10
Rewards Points: 6,652
Natural gas does not have a smell. What you are smelling, is the chemical butyl mercaptan or Butanethiol, which is used to give it its smell. https://en.wikipedia.org/wiki/Butanethiol Dry drains will give off almost the same smell, and can be just as flammable.
Old 11-28-2011, 03:29 PM   #11
Superswid's Avatar
Thanks for all the input. No basement so I'll just try running water and flushing toilets etc when I get home from work today. Hopefully that will fix this issue.
Old 11-29-2011, 11:20 AM   #12
Superswid's Avatar
Well I went home and ran all of the sinks/showers for about 15 minutes. When I then opened the windows and air flowed through the place, no scent was detected. This was the first time we've opened all the windows and not had that noxious gaseous odor permeate the entire house. Again this morning we opened everything up and no scent. It's hard for me to believe that we've lived in the house for over a month and that the traps hadn't been filled, if that was the issue, by now. But who knows. Perhaps there was some residual methane left over that needed a good flushing out. All I know is that for the first time since we've been here, the air smelled good when we opened up the windows and air flowed in the house. Unless I was wrong about the creation of air flow through the house triggering the odor, which I don't think I am, and that it will return again, it seems that the problem has been resolved. Crossing my fingers.
Old 11-29-2011, 11:38 AM   #13
Ironlight's Avatar
With the house closed up there was no pressure change and nothing to draw gas out of the sewer lines. Opens some windows on any given day and you'll get negative pressure somewhere in the house that will draw gas up out of the sewer lines if the trap are dry. So I would say you fairly certainly licked your problem.
Ironlight is offline   Reply With Quote
The Following User Says Thank You to Ironlight For This Useful Post:
Superswid (11-29-2011)
Old 11-29-2011, 11:42 AM   #14
Superswid's Avatar
Alot of negative pressure - the air flow through the house when opening opposite side windows simultaneously is like a freakin vacuum, which we love because of all the (hopefully now) fresh air that circulates through the house.
Old 11-29-2011, 11:45 AM   #15
gmhammes's Avatar
Did anyone paint with oil based paints? I had a similar issue and it was because i had painted and then had the heat on in the house. the gas company said the affect from the oil paint and heat create that smell and it would go away in a couple of days and it did.
gmhammes is offline   Reply With Quote
Weird wiring in house fdmillion Electrical 13 06-14-2013 07:49 PM
Considering buying a house that needs regrading HELP Dr.JUSC Landscaping & Lawn Care 9 06-16-2011 11:58 AM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 06:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
natural gas install to existing house sagechickie Building & Construction 9 04-22-2009 10:44 PM
