Natural Gas To LP Conversion - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-26-2011, 12:55 PM   #1
natural gas to LP conversion
My dad recently gave me his natural gas grill. My house is all electric, so I would like to covert the grill to run on LP. Can I just go to Home Depot or Lowes and buy a hose and regulator for LP and put it on? Any help would be appreciated. Thanks.
John
johnl0958 is offline   Reply With Quote
Old 04-26-2011, 01:06 PM   #2
A Little Of Everything
Rewards Points: 1,364
John
No.
LP Gas runs at a considerably higher PSI, so the orifice will be smaller.
DrHicks is offline   Reply With Quote
Old 04-26-2011, 01:09 PM   #3
Experienced
Jackofall1's Avatar
The short answer is yes, first I would look online at the manufacturers web site, many will sell the conversion kit specific to your make and model. The difference is the size of the orfice, it needs to be the correct size for the BTU output of your BBQ, and I know brand "L" does sell the kits for the models they sell at least.
Mark
Old 04-26-2011, 01:11 PM   #4
Experienced
Jackofall1's Avatar
Originally Posted by DrHicks View Post
No.
LP Gas needs an orfice change due to BTU's/cf not for reasons of pressure.
Old 04-26-2011, 01:16 PM   #5
No.
I thought the regulator was to bring down the pressure from the propane tank to the grill. Is it possible to also control the pressure by not opening the valve on the tank all the way?
Mark
I have asked the manufactuer (Ducane) if they sell a kit, and they said no. Also the grill is like 10-15 yrs old.
How do I know how much BTU I need?
Old 04-26-2011, 01:50 PM   #6
Experienced
Jackofall1's Avatar
NO, you cannot regulate pressure using a valve, you MUST use a regulator, the orfice is located down stream of the regulator.
Look at Ducanes web site and see if you can match your up (close to) whats available today, look at the btu rating, also, see if they have replacement burners for your, they are also rated in BTU output.
Mark
Old 04-26-2011, 02:31 PM   #7
Mark
k, thanks for the help.
Old 04-26-2011, 02:43 PM   #8
Experienced
Jackofall1's Avatar
You could look at these, see if you can match your model number.
http://www.appliancefactoryparts.com...ng-valves.html
Old 04-26-2011, 03:15 PM   #9
Yeah, I should have been clearer on that. Thanks for the correction!
Old 07-30-2011, 06:05 PM   #10
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
From what I am seeing, the conversion kits run about $50. Does that sound right? My grill gave out and I bought a Weber charcoal grill for now. I would like to look around for a good buy on a Weber NG grill, but I want the ability to switch to propane without spending gobs and gobs.
WirelessG is offline   Reply With Quote
Old 07-30-2011, 11:20 PM   #11
WirelessG,
When looking for your new NG Weber grill just make sure that it comes with the LP kit. It should just consist of orifices, if I'm not mistaken.
VIPlumber is offline   Reply With Quote
Old 07-30-2011, 11:38 PM   #12
this place had ducane orifice listed. said they would drill it to size
http://www.clagrills.com/allgrillpar...all-valves.htm
Old 07-31-2011, 06:18 AM   #13
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
I had a grill at my old house ( Charbroil I think it was) and all i had to do to convert it to NG was remove the orifice altogether. Before you buy a new grill, take a look at the online manual to see if what's involved to change it over
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 07-31-2011, 07:44 AM   #14
Rewards Points: 5,336
You should be able to remove the orifice and take it to a grill parts place for a replacement to the gas you're planning to use. If you can't find it, you can drill out the orifice to the diameter needed.
I think this was discussed in the past on this forum with the drill bit diameter needed.
Ron
B. Franklin 1759
Old 07-31-2011, 08:56 AM   #15
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
I used silver solder to close up the natural gas orifices and then drilled them out to the correct LP BTU rating. Here is sizing chart:
http://www.grillparts.com/howto/btu_guide.htm
A full service propane dealer can do this if you are not comfortable with it. You will also need a regulator and hose.
For information, the reason you need different (smaller) orifices is that propane even after regulation is a higher pressure than natural gas.
Propane (LP) is 11" WC (11 inches water column) , about 1/2 PSI
Natural gas runs at about 5-7" WC , about 1/4 PSI (I have rounded off all numbers).
Coastal South Carolina
natural gas to propane conversion Brian U Appliances 1 09-28-2009 11:36 AM
Flexible Natural Gas pipe/Line andy5111 Plumbing 10 09-25-2009 10:41 PM
Painting natural wood windows lauries Interior Decorating 5 04-02-2009 07:07 PM
Propane to Natural conversion higgsfamily5 Appliances 5 11-06-2008 09:51 PM
Natural Gas to L.P conversion on stove. RobertS Appliances 4 03-10-2008 12:06 PM
