Narrow Mounting Space For Blinds - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-03-2010, 05:11 PM   #1
Rewards Points: 31
Narrow Mounting Space for Blinds
We need to install some horizontal blinds on our windows. The size of the window causes us to have to mount it from the inside the window frame, unless we pay custom pricing. We prefer not to if we can avoid it.
i have enclosed a picture of our window frame. We have a 1/2" mounting space and the wood is manufactured instead of being real wood. You can see the mounting space to the left of the metal bracket in the picture.
Is there anyway to make this happen?
Thanks,
Randal
sharingsunshine is offline   Reply With Quote
Old 08-03-2010, 07:15 PM   #2
Rewards Points: 5,336
You can have Levelor blinds cut to size at Home Depot. Cost is under $20.00, even for large windows.
Ron
Old 08-03-2010, 07:23 PM   #3
Superintendent
Mudpad's Avatar
Ask for "micro blinds" they are 3/4" (i think) instead of the standard 1" minis.
Mudpad is offline   Reply With Quote
Old 08-04-2010, 08:10 AM   #4
Rewards Points: 31
Thanks for the suggestions. However, my problem is the mounting space, for the brackets, inside of the windows. I only have 1/2" of space and the surface isn't real wood either.
All the mounting brackets I have seen are much wider. Do any of you know of a workaround?
Thanks,
Randal
Old 08-04-2010, 08:19 AM   #5
Rewards Points: 558
Here you go, this link should help you out: http://designerblinds.com/CSTips/CSTips_036.htm
epson is offline   Reply With Quote
Old 08-04-2010, 09:57 AM   #6
Rewards Points: 31
Thanks, that is what I need. Now I just need to find where they sell them locally. Any ideas, I looked online at Sears, Lowes and Home Depot?
Old 08-04-2010, 10:07 AM   #7
Rewards Points: 558
You can try your local blind store and if they donít have them in stock Iím sure they can order them for you.
Old 08-04-2010, 11:14 AM   #8
Rewards Points: 31
Thanks again.
Old 08-05-2010, 09:33 AM   #9
Rewards Points: 558
No problem, we are all here to help one another outÖ
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 12:57 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Space needed for L-shaped staircase with 2 landings redpanda Building & Construction 1 07-28-2010 06:32 PM
Mounting Checkolite pot rack with lighting Warner Electrical 2 06-16-2010 01:56 PM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 08:15 PM
