Name That Tool! - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-11-2011, 07:05 PM   #1
jules4's Avatar
Name that tool!
I need some help identifying a few of the tools in my great-grandfathers tool chest, and hoping there are some old-timers (or fellow old-timer-wanna-bees) on this site who can help me out.
(Correction to pictures: I should have labelled the objects 'UDTs,' since I think they were all produced in Canada.)
For what it's worth, here's the tool chest in question:
jules4 is offline   Reply With Quote
Old 07-11-2011, 07:06 PM   #2
jules4's Avatar
UDT (unidentified domestic tool) 1:
Edited to add: has been identified as wire pliers
Old 07-11-2011, 07:12 PM   #3
jules4's Avatar
UDT 2:
Edited to add: has been identified as a sanding block
Old 07-11-2011, 07:17 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Post #3 is a sanding block I think. Those things are still available today in a plastic version.
The sandpaper is cut the width of the block and long enough to be tucked first into the narrow slot then wrap around the block one time and again tuck into the other slot. There are reliefs in the edges of the blocks for a finger grip.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
jules4 (07-11-2011)
Old 07-11-2011, 07:17 PM   #5
Rewards Points: 558
Originally Posted by jules4 View Post
UDT 2:
My guess is that this is some kind of support that is designed to slip over a wire (no idea what it would be supporting though).
That’s an old sanding block. You cut the sand paper to size, bend it over and place into the groves and sand away…
epson is offline   Reply With Quote
The Following User Says Thank You to epson For This Useful Post:
jules4 (07-11-2011)
Old 07-11-2011, 07:20 PM   #6
jules4's Avatar
UDT 3:
I really, really hope someone knows what this is, because it's been driving me nuts trying to figure it out.
One end appears to be designed to be held by a brace, the other end - I don't know, maybe it fits over a nut of some sort?
And I have absolutely no clue what the complicated mechanism in the middle is supposed to accomplish - it slides up and down, and locks into position, and the amount of slide can be increased by partially unscrewing the two sections (but they can't be unscrewed to the point of coming apart).
Sliding the sections does not cause either end to rotate and there is no ratcheting mechanism involved.
ARRRRRG!!! What is this thing
Edited to add: has been identified as a Yankee bit extension # 2150
*does happy dance*
Old 07-11-2011, 07:21 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Post #2 looks like an early version of a "Lineman's" pliers. It has three cutters and the square notch in the nose portion if for gripping two wires together for twisting.
XXX
Old 07-11-2011, 07:24 PM   #8
jules4's Avatar
UDT 4:
I think all three of these objects are for bending pipe, can anyone confirm this?
Old 07-11-2011, 07:25 PM   #9
Rewards Points: 558
My first guess was that it was some sort of fancy wire cutter, but it has no cutting edges. I then though it might have been used as a crimper - but why would you need to crimp 3 things at once?
And there’s the matching ‘v’ notches in the upper and lower jaws (they form a square opening about the same size as the three pairs of offset notches).
That looks like an old fencing plier which was a good general purpose cutting, bending and tying tool to have around when you were making a wire fence.
Old 07-11-2011, 07:26 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Post #6
May be a furniture makers nut driver. In the day all threaded nuts were square. The adjustment would serve as a "stop" so as not to over-tighten the nut against the wood. Just guessing.
XXX
Old 07-11-2011, 07:30 PM   #11
jules4's Avatar
UDT 5:
Last one - is this a hand drill for rock?
It feels like it's made from regular old iron, so I can't imagine it would be hard enough to drill rock, but not sure what else it could be. (I could really use a rock drill, so I may just give it a shot with this thing and see what happens.)
Edited to add: has been identified as probably a hand-made awl
Old 07-11-2011, 07:32 PM   #12
jules4's Avatar
Awesome - I could use another sanding block!
Old 07-11-2011, 07:36 PM   #13
Rewards Points: 558
UDT 5:
this is what they are: http://www.builderbill-diy-help.com/...nd-wedges.html
Old 07-11-2011, 07:40 PM   #14
Rewards Points: 104
Yup, the sanding block is obvious enough, probably a bit more recent that the other items, and my money would be on the pliers being for fencing. Have you tried a bit in the end of the long piece? It may have considerable wear, but my guess is that the thumb catch allows you to turn the end piece, so that you can line up the flats, insert the bit, turn the end piece back in place, and have an extension for boring through larger timbers. The last item is probably a hand made awl, and, sadly, the items before that are similar to what many of here have in our boxes or drawers; accessory items for something else, of which you may or may not ever identify the mate, as it may even have been tossed at some point. I would definitely hold onto them though, as it may hit you in the middle of the night sometime.
Old 07-11-2011, 07:45 PM   #15
Rewards Points: 104
By the way, I might clean it up with some Murphy's soap, or something like that, but would not make any attempts beyond that at restoring the box. As for the bevel and other items, I have had great results maintaining the originality while making useful some of my dad's and granfathers tools, as well as others that I have picked up along the way, with a little motor oil and very fine steel wool, then rinsing the rusty residue off with WD40.
Tags
antique tools , old tools
Clamping tool or Oscilating tool for a DIY'r-you can only pick one which would it be? whataboutj Tools 12 11-29-2010 07:12 AM
Review: Harbor Freight Oscillating Tool Tedstor Tools 0 07-13-2010 02:24 AM
Need Help with re-design ttwiss Remodeling 21 05-08-2010 10:27 PM
Fein's Multimaster Tool...don't let the price scare you! CrossWorks Tools 13 04-18-2009 06:39 PM
Drywall Inside Corner Tool? helpless handyman Drywall & Plaster 24 02-19-2009 06:02 PM
