Name This Item - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-07-2011, 06:49 PM   #1
Name this item
I am in need of a few simple devices. The item mounts on a wall switch cover plate and is secured by the two mounting screws. It's purpose is to prevent accidental "turn-on turn-off" of the switch. To operate switch, you must slip a finger under this "guard". I have seen them in the past but don't know what they are called or where to buy them.
Giles is offline   Reply With Quote
Old 02-07-2011, 07:24 PM   #2
fabrk8r
fabrk8r's Avatar
Google "light switch guard"
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 02-07-2011, 07:28 PM   #3
fabrk8r
fabrk8r's Avatar
It would be pretty simple to make your own from scratch using a strip of plastic cut from a milk jug with a couple holes punched in it for the screws.
The Following User Says Thank You to fabrk8r For This Useful Post:
Giles (02-07-2011)
Old 02-07-2011, 07:50 PM   #4
Rewards Points: 160
Look for them near the red furnace switch cover plates. They are cheap. Not as cheap as the home made version, but a lot better looking....
cgoll is offline   Reply With Quote
Old 02-07-2011, 08:08 PM   #5
remodeling pro
Don't know if they still carry them, but they used to be available at Lowes or Home Depot. Good shot at finding them if you have a large Ace hdwr nearby also.
troubleseeker is offline   Reply With Quote
The Following User Says Thank You to troubleseeker For This Useful Post:
Giles (02-07-2011)
Old 02-07-2011, 09:04 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,710
Ayuh,... I've been bending my own outa .045 SSteel weldin' wire....
Old 02-07-2011, 10:17 PM   #7
I just got some of those switch covers at Lowes last week in the switch isle hanging on a clip strip.
Shockme is offline   Reply With Quote
Is there such an item? veesubotee HVAC 4 09-01-2010 06:13 PM
Anyone know what this hardware item is? Havoc General DIY Discussions 2 12-04-2009 12:00 AM
Cool Tools Builders' Show 2009 in Vegas -item help DesertPaso Tools 7 09-24-2009 01:41 AM
[Pics Inside] Unsure what this part does (electrical fireplace switch) rdiggidy Electrical 4 09-07-2009 06:14 PM
