Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-30-2009, 03:22 PM   #1
deg
Cool
Nails, Screws in Concrete-Curtain Rods
Greetings All,
We live in a old cinder/concrete block home that we rent. I have had to change the curtain rod over a large window and I used masonry nails. Well, I want to change the rod and the curtains. My question is should I use masonry nails or is there a better option. This house has many nail scars and I don't want to cause more.
Also, is there an advantage to putting up drywall over concrete walls?
Again, we have a mold problem on the inside of the house around the outside walls. Does seem mean we have foundation problems? There is a crawl space underneath.
Thanks, DEG
deg is offline   Reply With Quote
Old 10-31-2009, 06:53 AM   #2
Tapcon screws work well, leaves a small hole to patch when you leave.
Old 10-31-2009, 09:04 AM   #3
I second the Tapcon recommendation. Especially with concrete block, rather than pounding in a big fat nail you drill the correct size hole and then thread in your Tapcon screw. They will have a whole section of them at HD including the drill bits.
Salem747 is offline   Reply With Quote
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 05:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
