Nail Bounces When Hammered In Wall. How Do I Hang Shelf - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-27-2010, 06:39 AM   #1
nail bounces when hammered in wall. How do I hang shelf
I think there are metal studs. not sure. Stud finder say wood but when I hammer nail it bounces. How can I hang a shelf when the nail won't penetrate the stud?
CarolPotter is offline   Reply With Quote
Old 06-27-2010, 07:57 AM   #2
DIY staff
Rewards Points: 7,174
Two possibilities---I suggest using a screw---that will penetrate the metal.
You will want to check and see if the 'stud' you found is a stud--not an air duct--electrical conduit or water pipe.
You should not have to much trouble finding real studs if you try this.
Use some painters tape or post-it notes to mark your locations---studs are typically 16" apart.
Start at one side of the wall and start marking the stud locations with your stud finder--you will find that the real studs are 16" apart--the pipes,ducts and other false readings will not be.
Most pullout rulers have red marks every 16"--I hope this helps.
Worst case--poke a small hole in the wall and stick an L shaped length of wire through the hole and feel around inside the wall.----Mike---
Old 06-27-2010, 08:03 AM   #3
the Musigician
DangerMouse's Avatar
-=chuckle=- or just poke a really BIG hole in the wall and take a look!
It might be bouncing off a plumbing pipe....?
DM
Old 06-27-2010, 08:08 AM   #4
metal plate to protect wires
The older I get the better I was
Old 06-29-2010, 05:56 PM   #5
yea..lol run a screw into a pipe
johnrem is offline   Reply With Quote
Old 06-29-2010, 07:20 PM   #6
kwikfishron's Avatar
Rewards Points: 832
It has been my experience when nailing a board to a wall and all you get is a bounce, it’s because “You’re Hitting Nothing”.
If you hit steel (a steel stud, plate, another nail) you get no bounce, you get a brick wall.
If you hit a pipe, a hissss is what you get.
If you hit a wire, the toaster stops working.
So back to OP. Are you sure you found a stud?
kwikfishron is online now   Reply With Quote
Old 06-30-2010, 09:32 AM   #7
You are hitting a PVC vent pipe !
Old 06-30-2010, 09:50 AM   #8
the Musigician
I think we have the winner folks! "Bounce" being the big clue.
DM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 03:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
