Mysterious Smell Under Kitchen Sink - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-21-2011, 08:23 AM   #1
I'm stumped on this one......
The cabinet under my bar/prep sink in my kitchen has a really strange and somewhat strong odor that I cannot pinpoint. Just curious to see if anyone has any ideas.
The entire kitchen (and about 90% of the house) just finished a major renovation about 4 months ago. This sink is completely new (new drain, supply lines). No disposal, just straight basket strainer into P trap. The plumber did use a mechanical (studor) type vent.
The smell I'm getting isn't mold, rotting food, or sewer smell. It's a chemical/powerdy smell. I scrubbed out the cabinet several times. I'm using a stainless sink and heard the insulation pads could add to the smell, so I tried encapsulating the bottom with polyurethane/kilz. Didn't do anything.
I'm using the same sink (larger), same mechanical vent, only with a disposal in my main sink, and no smell.
Any ideas?
Thanks for letting me vent.
-JimmyCrackCode
jimmycrackcode is offline   Reply With Quote
Old 10-21-2011, 01:07 PM   #2
Rewards Points: 5,336
Dead animal?
Open the kick plate and have a look.
Is this room over a basement or crawlspace?
Ron
B. Franklin 1759
Old 10-21-2011, 01:14 PM   #3
Over basement. Dead animal.........interesting. I'll poke around.
Thanks.
Old 10-21-2011, 01:18 PM   #4
Thanks.
Even a mouse can stink, though not really a chemical smell.
Ron
B. Franklin 1759
Old 10-21-2011, 11:16 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 112
A dead mouse can smell really bad.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 10-21-2011, 11:24 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The good thing about dead rodents...well there's two good things actually:
1. They are dead.
2. The odor eventually goes away.
Old 10-21-2011, 11:43 PM   #7
Military Mom of 4
Snav's Avatar
Dead creatures smell somewhere between rotting food and sewer - I've smelled my share.
What are your pipes? PVC it sounds like. . . do your pipes go through the floor to a crawlspace or down/up a wall?
Might be cpvc or pvc adhesive, plumbers putty - but if it's getting stronger it might be a chemical that's calcified and activated with humidity/moisture - I'd scrub the area with odo-ban or other such cleaner that neutralizes acids and see where you stand.
Have you removed the trap to see if there's something festering?
But you know - with your studor vent in place as an alternative to a vent pipe out of the house it might just be a release of these gases and vapors - some people swear they're not suppose to odorize your room but I think they do exactly that: funk it up. Does it have a carbon filter - have you tried changing it?
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Kitchen sink not draining, is it the vent? gdav Plumbing 18 02-12-2013 03:38 PM
Why does my Kitchen Sink Smell? Syz Plumbing 10 10-30-2011 10:13 PM
Kitchen sink centered on cabinet? sillyboy22 Plumbing 3 03-02-2010 09:16 PM
Need help re-routing kitchen sink vent Fingers Plumbing 11 10-23-2009 03:17 PM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 10:10 AM
