Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-29-2006, 01:10 PM   #1
Property Manager/Landlord
Mysterious leaking roof... Suggestions?
A year after we bought our home, we noticed water damage in the drywall on our second floor (vaulted ceiling, so no attic). I liberally coated the roof (asphault shingles) with a heavy aluminum coating. All was well for a while. No leaks.
Some months went by, and we had a heavy rain and the water just rushed in. Seemed to start at the peak and run down the old rafters and stopped at the walls. So I now have a water stain from the peak to the walls. Lovely. Just lovely.
I do a solid inspection of the roof paying exta attention to the roof cap, thinking there might have been a loose shingle. All is solid, nothing noticable that would allow water into the house. As mentioned, this roof was heavily coated and well sealed!!
Now, our home is older and has a slight slope in the center of the roof. I noticed that during certain long-term rain fall that no water leaks in. But during other rains, the water gushes in. Could it be that I have a leak near the gable-end of the home and the water follows the main header into the center of my home and then follows that rafter down to the wall?
Since the roof is solid, I am convinced that there is another avenue that the water is sneaking in. Any suggestions or comments appreciated.
steve
AlbrightPM is offline   Reply With Quote
Old 10-29-2006, 02:34 PM   #2
World famous jerk.
You coated an asphalt shingle roof with aluminium roof coating? And you're surprised it leaks? Tsk-tsk.
My suggestion is to replace the roof and quit monkeying around slathering crap on top of it.
mdshunk is offline   Reply With Quote
Old 10-29-2006, 03:25 PM   #3
747
registered
747's Avatar
You turn a bad stituation into a worst stituation. I don't understand why you would have coated that roof. My advice is ripped that roof off and replace it. Unfortunately depending on the size of your house a 30 year shingle is going to probably run in around 3500.
747 is offline   Reply With Quote
Old 10-29-2006, 04:04 PM   #4
Master Craftsman
Big Dave's Avatar
I totally agree with the other two. Caulking or tar or whatever it is has no place on a roof. 99.9% of the time it will just cause it to leak worse or make the problem harder to find. Replace the roof or at least hire a professional to look at it.
Another thing you could do is to cut a patch out of the ceiling since it is ruined anyway and wait for the next rain and try to follow the leak and see where it is coming from.
Do one thing at a time, do it well, then move on.
Big Dave is offline   Reply With Quote
Old 10-29-2006, 08:58 PM   #5
This might help!
http://buildscanir.com/index.php
stuccoman is offline   Reply With Quote
Old 10-29-2006, 09:47 PM   #6
I should clarify... it's meant for asphalt roofs, but has that aluminum goop in it that reflects the heat. Sorry...
steve
Old 10-29-2006, 09:59 PM   #7
Building inspector
inspects's Avatar
Is water coming in a ridge vent?
inspects is offline   Reply With Quote
Old 10-30-2006, 11:44 AM   #8
Commercial Flat Roofing
No need for clarification on the roof coating.
Roof coating (aluminum or not) is for flat roofs, not shingles.
Talos4 is offline   Reply With Quote
Old 10-30-2006, 11:47 PM   #9
Shows how ignorant I am about roofs. I typically don't touch anything on the exterior. This was my own home and I went by some alleged "wisdom" from the older generations.
Thanks for the advise and suggestions.
steve
leaking tar and gravel roof meleis Roofing 9 01-05-2008 11:27 PM
Leaking roof -recommend a roof coating? Faust Roofing 5 07-12-2007 11:09 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
Help- leaking flat roof, alum?metal? xoroniox Roofing 1 04-24-2006 12:03 PM
Seller covered bad roof up, suggestions? imetal Roofing 11 03-05-2006 09:03 PM
