Mysterious Hole In My Basement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-18-2014, 01:21 PM   #1
Unhappy
Mysterious hole in my basement
Hi I'm new to the site so I hope I do this right.....yesterday I noticed a random puddle of water at the threshold of my utility room in my basement...I though my dog decided to make that a bathroom spot....but after doing the dishes I noticed the puddle was bigger....after inspecting to see where the water was coming from I found this mysterious hole in the concrete....so I ran the water continuously in the kitchen and found the water was coming out of this hole.....does this mean a pipe has busted underground....does the city cover that or my homeowners insurance? What am I dealing with here???? Please help!!
Mysterious hole in my basement-img_20140318_130348.jpg   Mysterious hole in my basement-img_20140318_130138.jpg
narsh27 is offline   Reply With Quote
Old 03-18-2014, 02:31 PM   #2
iminaquagmire's Avatar
Rewards Points: 338
Most likely not the city's responsibility. I can think of no reason for a 1" hole to be interconnected with your house's sewer lines (kitchen sink part of story). That's not to say it isn't possible. You have some kind of underslab leak or drainage issue for sure. It is pretty much impossible to tell you more than that from the pictures. I'd have a plumber out to look at it and camera your drains.
iminaquagmire is offline   Reply With Quote
The Following User Says Thank You to iminaquagmire For This Useful Post:
narsh27 (03-18-2014)
Old 03-18-2014, 02:58 PM   #3
joed's Avatar
Rewards Points: 12,848
Turn the pictures right side up.
It most likely means that line once a drain connected to it. Or it is a floor drain.
The water backing up could be because your main line is partially clogged and causing a back up. Have you main line cleaned and video inspected. You have to pay for it.
The Following User Says Thank You to joed For This Useful Post:
What is this hole in the basement floor?? kamkon Flooring 4 09-20-2012 12:53 PM
Basement moisture/humidity issues amason2308 Remodeling 2 09-12-2012 08:27 AM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 10:08 AM
Filling a large hole in basement! rotteneggz Building & Construction 4 10-01-2010 06:11 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
