Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-13-2011, 02:06 PM   #1
My new rotary hammer drill wobbles.
I just bought a new Bosch Bulldog Xtreme rotary hammer and the chuck has a really bad wobble to it. I understand the these types of drills have some play in the SDS-plus bits but this is a very noticable wobble. The tips of drill bits make little circles in the air, and I can feel the clutch/chuck doing the same. It's not that the bit 'wobbles' around, it's actually held in the chuck a slight angle
When I called Bosch, the technician just kind of brushued it aside and told me it was normal and not to worry about it.
Has anyone else seen this?
-rick
rick112 is offline   Reply With Quote
Old 04-13-2011, 02:16 PM   #2
Learning by Doing
Leah Frances's Avatar
Where did you get it? Take it back.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-13-2011, 03:41 PM   #3
Persona Non Grata
VIPlumber's Avatar
It's not normal. I agree w/ Leah.
VIPlumber is offline   Reply With Quote
Old 04-13-2011, 03:50 PM   #4
nap
You talking to me?
nap's Avatar
check this with several bits, in the same manner you have; holding the bit into the air and look for wobble. If only one bit does it, the bit is bent. If they all do it, the shaft is bent or there is something wrong with the chuck.
If the problem is with the drill, take it back. It is not normal, typical, or acceptable.
Old 04-13-2011, 04:10 PM   #5
I checked it with a few bits. It's definitely the drill.
Thanks. I knew that Bosch tech was just trying to give me the brush off.
-rick
Old 04-13-2011, 08:31 PM   #6
Learning by Doing
Nap - you teach me something new, just about every day.
Old 04-13-2011, 09:33 PM   #7
I have the Bosch Bulldog Xtreme and while there is some play in with the SDS bit, there is no wobble at all on the drill.. just as solid as any other normal drill. Take it back...
grantala is offline   Reply With Quote
Old 04-13-2011, 09:34 PM   #8
Ironlight's Avatar
Faulty chucks are the #1 reason for returns of new drills. Take it back and exchange it post haste. There should be no wobble, play, or other funny business of that sort whatsoever, even in an inexpensive model
Ironlight is offline   Reply With Quote
Old 04-13-2011, 10:34 PM   #9
The cordless hammer drill action is nowadays found on many drills. When first introduced on cordless drills, the hammer movement was not very powerful or a very reliable feature. With improvements in power cell technology and popularity of cordless batteries, and the hammer feature cordless drills has received greater and greater esteem. Let's look at the cordless hammer drill to see if it is really a viable alternative for a professional woodworker:The hammer action allows you to drill holes quickly into stone or any kind of masonry type material. While still rotating, the chuck and drill bit is still pushed forward usually by a spring sitting on an eccentric flange inside the cordless drills gearbox. This backward and forward movement is what causes a kind of "hammer" action pushing the drill bit forward.
Last edited by Gary in WA; 04-13-2011 at 11:44 PM. Reason: removed website link in post body per rules.
jencymikki is offline   Reply With Quote
rotary hammer drill or standard hammer gramps416 Tools 24 04-23-2013 02:34 PM
Rotary Hammer Drill Information Giles Tools 2 02-06-2011 02:03 PM
Rotary Hammer Drill vs Hammer Drill jrepp44 Tools 6 06-29-2010 07:07 AM
rotary hammer drill ctkeebler Tools 8 04-10-2010 10:42 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 01:01 PM
