My Gate Has Become Very Tweaked - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-02-2012, 10:38 PM   #1
I love my new front yard!
Telfair's Avatar
Rewards Points: 158
My gate has become very tweaked
It started out straight but seems to be getting worse?
Seems the strap don't help & might actually be a large part of whats pulling it up in that bottom corner.
Whats the easiest repair for this?
I have some ideas but wonder what you might recommend?
My gate has become very tweaked-img_2989.jpg   My gate has become very tweaked-img_2990.jpg   My gate has become very tweaked-img_2991.jpg   My gate has become very tweaked-img_2992.jpg
Telfair is offline   Reply With Quote
Old 07-03-2012, 01:11 AM   #2
Rewards Points: 2,212
One solution - take off the cable, use flat metal making an X
May need to remake the frame part too.
mae-ling is offline   Reply With Quote
Old 07-03-2012, 01:16 AM   #3
Renovations contractor
Bonzai's Avatar
Get a gate hardware kit and start over. The twigs aren't adding any structural integrity and the cable is twisting the frame.
Home Renovations & Repairs
ADVENT HOME SOLUTIONS INC
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
Old 07-03-2012, 02:37 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 2,120
How are those posts put into the ground? I think you have several issues. Part of the problem is that your never going to get a gate frame like that to stay plumb and square.....
ddawg16 is online now   Reply With Quote
Old 07-03-2012, 07:11 AM   #5
biggles's Avatar
the weight of the gate is going right down that cable.need to remove it or add another for an X so all the corners have a pull tension..how much does that weigh? can you lift it with one hand? might want to add another lenght of 2x4 in the gate where it swings on those hinges...
Old 07-03-2012, 07:13 AM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 776
The gate frame is not heavy enough, also treated 2X4s are bad to twist and curve but then so are 4X4s. If it is the cable pulling the frame out, put another cable on the other side of the gate to pull it back the other way.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 07-03-2012, 01:54 PM   #7
Telfair's Avatar
Rewards Points: 158
That might just work?
I was actually thinking about placing some diagonal 2x4's in the frame, but might the 2nd cable alone fix it?
Old 07-03-2012, 02:19 PM   #8
Rewards Points: 14,306
As stated many differnat ways, that gate was build completly wrong in the first place, adding a brace will do nothing to "fix" that one.
If you Google "building a gate" there's hundreds of sites showing how to build one that should not sag.
Old 07-03-2012, 03:42 PM   #9
Another cable is not a good idea.
If you like that style build a new one with a metal X brace on the back.
Can even re-use the branches from the old one.
You "MIGHT" (emphasis might, be able to just add an X-brace to that gate, although because it is already twisted that is probably not the case.
Old 07-03-2012, 08:29 PM   #10
Telfair's Avatar
Rewards Points: 158
I'm not grasping this metal X can someone show me a pic of what they mean?
Old 07-03-2012, 10:21 PM   #11
JOATMON
ddawg16's Avatar
Take your gate frame...draw an X across it....
But still will not solve your problem. It may keep it square, but it won't stay straight. The outside frame of the gate is nothing more than pressure treated 2x4's that look like they are screwed together. There is no way your going to keep them straight (vert). Not enough holding power with the screws into that soft wood.
If you want to do it right....go down to a wrought iron shop....have them make you a gate frame out of wrought iron....then you can hang your limbs on that.
Old 07-04-2012, 05:29 AM   #12
kwikfishron's Avatar
Rewards Points: 998
You’re going to need to start over.
Forget the pt lumber and use Redwood.
Make your center horizontal a 2x4 and install a 1x4 Redwood “let in brace”. Forget the metal, it looks too cheesy for what you’re going for.
One let in brace will keep it square but two, one on each side creating an X might look better.
The tighter the grain in the 2x4’s the better.
kwikfishron is offline   Reply With Quote
Old 07-04-2012, 05:51 AM   #13
Rewards Points: 998
Actually Jim, that incised treated post is Fir and is pretty stable and is the norm out West.
In all my years I never met a Yellow Pine post until I moved to the Mid West. I never knew wood could move so much.
The 2x4’s in the gate look like what they call “outdoor wood” which is usually treated Hemlock. The Hemlock will twist, cup and check but not even close to the extent that I’ve seen with the Pine.
I've never seen treated Pine on the West Coast and hope I never do.
Old 07-04-2012, 10:15 AM   #14
The Metal X - Take a strap of metal say 1.5" wide and 1/16th or so thick run it from top right to bottom left corner.
Then take another from the bottom right to the top left so you have an X. Can weld it or bolt it where it crosses.
As said one diagonal will do it but 2 will probably look better.
Can do it with wood but the larger size of the wood may not be the look you are after, Or maybe it is.
Suggestions for a 12ft wide wood gate? bikerider138 Carpentry 14 12-07-2010 09:40 AM
Need to ID Gate Valve (Please Help) MikeGV Plumbing 3 10-04-2010 11:02 AM
Gate Design Question rocknroll99 Building & Construction 5 04-13-2010 07:46 AM
Driveway Gate Construction Questions KP Texan Building & Construction 3 07-30-2009 08:45 PM
