Murray Snowblower - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-18-2009, 05:43 PM   #1
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,358
Anyway, is there an adjustment to make on the blower
Ayuh,... Could you be alittle more specfic,..?? Belt adjustment,..?? Carb Adjustment,..??
Better yet,...
Explain what's Wrong with it....
Old 12-18-2009, 11:35 PM   #2
murray snowblower
Yeah I guess I do need to specify. I was referring to making adjustments to the belts. It doesnt throw as far as it use to.Thanks
lcsjim is offline   Reply With Quote
Old 12-21-2009, 11:32 AM   #3
Murray snowblower issue
Hi,
I also have a Murray/Noma snowblower. I have to replace one of the augers. It is a two stage blower. I can't figure out how to remove the old auger. I removed the screws supporting the auger on each side of the housing but the center gearbox is tied to the impeller and wonder if someone can give me an idea of how to remove the assembly. I thought either the auger assembly would have slid off the impeller shaft or the auger/impeller assembly would have slid out of the motor housing. The exploded parts view does not show any retaining rings anywhere.
tomwa1vta is offline   Reply With Quote
Old 02-20-2010, 03:51 PM   #4
Question
can't remove augers from Noma snowblower
Originally Posted by tomwa1vta View Post
Hi,
I'm having the same problem. Can't remove the auger assembly from snowblower. Drive shaft does not slide out.
Anyone know how to remove the augers. my welds cracked and need to have them re-welded.
homeower is offline   Reply With Quote
Old 02-20-2010, 04:15 PM   #5
Removing Noma snowblower augers
You have to break the blower in two at the point where the drive belts are and remove the flywheel by removing the nut that held it on. It's actually the rear of the impeller shaft. Then you can pull out the entire auger/impeller assembly and the augers slide off the shaft. Don't lose the key in the keyway. If you study the snowblower manual it will become clear.
Wish the side of the auger housing came off but it does not. It is welded on my model.
I also wish someone told me about this on this list instead of my reinventing the wheel.
Old 02-20-2010, 04:36 PM   #6
removing augers
thanks for your quick response and help.
This helps. I'll dig into the manual.
Old 02-20-2010, 04:46 PM   #7
removing augers
If it's a Noma, feel free to ask me any other questions that might pop up. I may (or may not) have some of the answers...
Murray Products Online? rustic Electrical 10 11-10-2009 07:25 AM
jammed snowblower Dee_M General DIY Discussions 11 11-27-2008 11:19 PM
Toro SnowBlower 521 metallic sound mteach General DIY Discussions 1 12-13-2007 12:27 PM
Murray Snowblower - Carb Problems? bob6831 General DIY Discussions 7 01-15-2007 10:08 AM
