Murray Lawn Mower - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-12-2006, 05:28 PM   #1
murray lawn mower
hello
i have a murray 42 in wide body riding mower the other day i was cutting grass, and it just stopped moving it will not go back or forward, i have checked the belt it is not broke , any ideas guys , thanks for the help
herbl38 is offline   Reply With Quote
Old 08-20-2006, 04:02 PM   #2
drive belt
I replaced my drive belt but can't get it adjusted enough. Any suggestions??
mannclan is offline   Reply With Quote
Old 08-20-2006, 05:12 PM   #3
Originally Posted by herbl38
hello
Does the engine run?
redline is offline   Reply With Quote
Old 08-20-2006, 05:13 PM   #4
Did you buy the correct belt?
It may be too long.
Old 08-20-2006, 07:44 PM   #5
Check to make sure the belt is properly set in the pulleys. I had the same problem and noticed the belt had loosened and come off the pulley. I routed it over the pulley and then adjusted the belt - there should be a tensioner on the mower to tighten the belt. That should work.
Douche is offline   Reply With Quote
Old 08-21-2006, 01:57 PM   #6
They're all fixer-uppers
J187's Avatar
Rewards Points: 508
Whoa dude, what's up with your user name? That's pretty, um, interesting...
J187 is offline   Reply With Quote
Old 04-27-2008, 10:16 AM   #7
Smile
need help
I need help finding the size belt I need for my murray 42" wideboy. I see you guys have this kind of mower. Can someone help me. The mower was given to me and the model and numbers I need are hard to read. Thank you.
silverbird129 is offline   Reply With Quote
fix my Lawn Mower Starter myself !!! KUIPORNG Landscaping & Lawn Care 10 06-28-2009 02:34 PM
Lawn mower question muchadu Landscaping & Lawn Care 2 04-01-2007 08:33 AM
Riding Lawn Mower Washer Willy Landscaping & Lawn Care 2 03-23-2007 01:25 PM
Rotary Lawn Mower jarg Landscaping & Lawn Care 9 07-03-2005 03:37 PM
