-   General Discussion (http://www.diychatroom.com/f2/)
-   -   murray lawn mower (http://www.diychatroom.com/f2/murray-lawn-mower-3461/)
herbl38 08-12-2006 05:28 PM
murray lawn mower
hello
i have a murray 42 in wide body riding mower the other day i was cutting grass, and it just stopped moving it will not go back or forward, i have checked the belt it is not broke , any ideas guys , thanks for the help
mannclan 08-20-2006 04:02 PM
drive belt
I replaced my drive belt but can't get it adjusted enough. Any suggestions??
redline 08-20-2006 05:12 PM
Originally Posted by herbl38
hello
Does the engine run?
redline 08-20-2006 05:13 PM
Did you buy the correct belt?
It may be too long.
:thumbup:
Douche 08-20-2006 07:44 PM
Check to make sure the belt is properly set in the pulleys. I had the same problem and noticed the belt had loosened and come off the pulley. I routed it over the pulley and then adjusted the belt - there should be a tensioner on the mower to tighten the belt. That should work.
J187 08-21-2006 01:57 PM
Whoa dude, what's up with your user name? That's pretty, um, interesting...
silverbird129 04-27-2008 10:16 AM
need help
I need help finding the size belt I need for my murray 42" wideboy. I see you guys have this kind of mower. Can someone help me. The mower was given to me and the model and numbers I need are hard to read. Thank you.
