Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-14-2008, 10:41 PM   #1
Multi-level drop ceiling
How can I build a soffit out of drop ceiling tiles instead of drywall, etc? I have to build a multi-level drop ceiling due to a metal beam and water pipes.
lb37illinois is offline   Reply With Quote
Old 11-15-2008, 12:19 AM   #2
Theres more then one way.
iMisspell's Avatar
You could always box out the beam and pipes with some nice wood trim/planks.
Im gonna run into the same thing when i go to finish my current basement, pretty sure thats the rout im gonna take.
If your fixed on your current plan ("instead of drywall, etc") how about some type of adhesive and maybe hinges for the pipes side so you can still have access to them if needed..
~ What was once an opinion, became a fact, to be later proven wrong ~
My current learning experience -
- Work shop, music-room, master bedroom above..
iMisspell is offline   Reply With Quote
Old 11-15-2008, 10:19 AM   #3
nap
You talking to me?
nap's Avatar
You build a frame from the same grid used for the rest of the ceiling. Small pop rivets, colored (to match the grid) are used to keep things together. If you cut the tiles tight, they will often stay in place by themselves. If they don;t you will need to devise a method of keeping them in place.
Old 11-15-2008, 12:15 PM   #4
You usually start with your main ceiling and use a main T runner where you want the soffit to start. Then you cut 2' T's and bend over a 1/4" or so lip to sit on top of the main T and pop rivet them using white pop rivets like mentioned. Then attach a peice of wall angle to the verticle T's with pop rivets and then use T's to build the under side of your soffit. It really helps to start things off using a bunch of those little clamps to hold things in place so if you need to you can make changes. If you have access to a 1/8" punch to make the holes for the rivets it really helps cause the grid won't move while your drilling it. I did commercial accustical ceilings for a while about 7 years ago so if you have any other questions i'll try my best to answer them. And to hold the verticle tiles in place they make clips, we called them alligator clips that clip to the T's and have tabs that hold the tiles in place.
ponch37300 is offline   Reply With Quote
Old 11-15-2008, 01:04 PM   #5
Drywall contractor
You can also wedge scrap pieces of grid between the flat part of the ceiling and the upright part to hold the tile. Cut a bit of a point on either end to embed it into the tiles. Cut your last piece tight. A "Whitney" punch and rivet tool are definite must-have items, as ponch said. Lots of clamps and string line to level it.
I usually frame and sheetrock drops if at all possible. Framing out of grid is much more time consuming and (in MY opinion) doesn't look as good.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-15-2008, 02:54 PM   #6
nap
You talking to me?
nap's Avatar
Oh, so that is what you call those things I here go "ting, ting ting" across the ceiling or onto the floor when I lift tiles up to do some work later
I hate those things. I have worked on jobs where they were required on all tiles and the carpenter was putting them on long before we got to do the lights..
Maybe doctors are right about your mind being able to block out bad memories. I forgot all about those.
Old 11-15-2008, 04:30 PM   #7
Drywall contractor
Yeah, you pretty much have to put them on as you go.......especially if you're working piece rate. And even if the ceiling mechanic leaves out the tiles where the lights go, the electrician has to take out another tile to wire up the pigtail. (Or another trade has to access something.) Shouldn't be a problem in the upright portion of a drop though. And they are mostly used in an application where "wind lift" is a problem (outside soffit/foyer of a commercial building).
Removal of paneling and drop ceiling margog85 Remodeling 14 07-25-2008 04:13 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
How to convert a drop rod ceiling fan to ceiling mount? Bacardi 151 Electrical 5 01-13-2008 09:04 PM
Work lights in basement with drop ceiling fw2007 Electrical 2 10-20-2007 10:39 AM
changing drop ceiling to normal ceiling acoustic_bum General Discussion 7 01-16-2007 08:52 AM
