Multi Adjust Door Hinges On Glass Doors - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-20-2010, 02:26 AM   #1
Multi adjust door hinges on glass doors
I have a cabinet on which on of the doors has dropped making it scrape on the bottom. I can see that there is an irregular gap at the top and have tried to adjust it but it's a nightmare with these hinges. Is there a simple way to do this. I know I can adjust the hang by altering the position of the big screw, but what is the purpose of the other screw?
hansi is offline   Reply With Quote
Old 07-20-2010, 08:15 AM   #2
Old School
Willie T's Avatar
These are the three most common adjustments. Usually there are three individual screws on each hinge to alter the situations shown here. One of those screws handles one of the directions of movement shown. Turn the screw to go one way (positive) and turn it the other way to move the door the other direction (negative).
Sometimes it is a "loosen the screw... move the door... re-tighten the screw" situation. In this case, just loosen each screw barely enough that the door will move. Makes it easier than getting the door flopping all over the place from really loose screws.
You can Google good, clear photos of how to do this online.
FranÁois Duc de La Rochefoucauld
Willie T
Old 07-20-2010, 08:20 AM   #3
Thanks both.
Replacing Sliding Glass Door w/ French Doors zapatero3 Remodeling 1 07-15-2010 06:01 AM
How do I remove sliding glass doors? upinsmoke Building & Construction 4 06-05-2010 05:41 AM
Patio glass doors re-purposed to deck railing glass? peterofCanada Carpentry 3 04-09-2010 12:34 PM
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 01:35 PM
8' Glass Sliding Doors dankreboot General DIY Discussions 6 07-10-2008 09:11 AM
