Moving An 8x10 Wooden Shed 100 Miles; How? (Video Of Shed Inside) - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-05-2010, 01:08 AM   #16
Originally Posted by Wildie View Post
That shed is of simple construction and can be disassembled easily!
Just saw off the nails with reciprocating saw. Lay the sections on a trailer and away you go!
My daughter bought a 8X12 shed that came in six pieces and we had it assembled in about 4 hours!
I actually think this could be a plausible idea. The reason I've been so hesitant to disassemble and then reassemble it has been because I've figured that there would be no way I could do it myself and it would cost a fortune to hire someone else to do it. But if I would be able to disassemble it myself (maybe with the help of a family member or two in that area as well) without too much effort and then load it into the back of a rented Uhaul truck, for example, and drive it home that would be significantly cheaper. All I'd have to pay would be the cost of the rental truck for 1 day, which isn't much.
Would you mind being more specific about how to disassemble/reassemble it though? For instance, what would I do about the walls/roof/floor which are all larger than 8 feet in one or both dimensions? Even the largest truck I could rent (1,611 cubic feet) is still only 7 feet 8 inches wide and 6 feet 10 inches tall so the pieces would be too big to fit into it. I don't see any way for the walls to come apart in the middle without maybe sawing them in half...and the front wall for example is 10 feet long and (approximately) 10 feet high. So I'm not sure how I'd get that to fit into the truck laying flat, up on its side, diagonally or any way really. And the issue still remains if I were to use a trailer instead of an enclosed truck bed...with the pieces all separated, laid on top of each other and strapped down, the height would probably not be an issue but the width still would.
snowfall is offline   Reply With Quote
Old 05-05-2010, 05:13 AM   #17
Rewards Points: 1,016
Originally Posted by tpolk View Post
please let us know, i have a feeling moving that distance will be the cost of a new shed. maybe you could air lift it
I was reading down the thread and thinking helicopter when I came to your entry.
Here there is a guy with a rig who specializes in moving seagoing cargo containers - and other large items. Somebody like that can probably make it happen.
Old 05-05-2010, 02:57 PM   #18
To move these sections, you will need 4 strong bodies! thats a given!
You will need 2 step ladders and an extension ladder ( separate the two sections!
The roof has two sides that are nailed to the ridge board. They are also fastened to the top plate of the walls. The rafters will have knotches cut into them, that are called birds mouths. The nails holding the rafters to the top plate will need to be sawn. The nails holding the rafters to the ridge board will have to be sawn also!
When the one side of the roof is loose, slide off and down.
The other side of the roof is done in the same manner, except the ridge board is left intact.
The walls are nailed to each other at the corners and these nails will have to be sawn also.
Nails holding the walls to the floor will have to be sawn or removed! There is a tool that is used for extracting nails from lumber! Its jaws are hammered down, around the nail heads, then the nails are pried out. You will need one of these for sure!
Not knowing what you paid, I hope that it was a nominal fee, as you can buy sheds like this for around $1000 and it will be delivered to your property. With no hassles!
Old 05-05-2010, 03:08 PM   #19
Newbie Bill
Rewards Points: 518
This shed must have been one heck of a deal. As was pointed out earlier, paying someone to move this for you will likely cost you more than a brand new shed.
But hey, I always open to being proved wrong.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 05-06-2010, 05:56 PM   #20
I did get a fairly good deal on the shed. I bought it mostly because I've been scouring the classifieds for months looking for a similar wooden 8x10 shed and they have all been $1,000 or more (most around $1,500, some going as high as $4,000), even the ones in terrible shape. A few months ago I found another 8x10 wooden shed in fine shape that someone was giving away for free that was only 20 miles from here; when I asked a local handyman about it he told me it would cost me about $500.00 to move and I told him that seemed like an awful lot and that I'd have to think about it. Turns out that while I was thinking about it, the handyman ended up going down and taking it for himself since it was such a good deal. So I missed out big time there, especially since with it being so close I probably could have taken it apart and moved it for half the price he quoted me.
I need the shed here before the end of the month, so with time running out and with me still being bitter after the realization that I missed out on a very rare opportunity, the instant I saw a similar shed at a reasonable price (AKA not thousands of dollars) I got it, since I didn't want to miss out again. Unfortunately my assumption that if I moved it myself it would only cost me one or two hundred dollars turned out to be very very wrong. Lesson learned, I suppose.
Also, three things:
First, if I was to disassemble it and then put it on a truck or trailer to be driven back home, approximately what size truck/trailer would I need?
Second, I had someone recently give me a quote that he and a few of the guys from his company could do the move for "about $300." They wouldn't be able to do it for another 2 weeks, I know nothing about the guy and it seemed like he was sort of guessing when he gave me the quote so I'm skeptical of taking his offer because all the other quotes I've gotten have been $1,000 or above and since if I committed the job to him and then once the move was done he told me it would actually cost me $2,500 instead of $300, I would be stuck. By all means tell me if you think I should take this guy's offer, though.
Third, I'm thinking back to the flatbed idea...if just the roof was removed and the shed was then tilted onto its back and rotated 90 degrees, it would fit onto a flatbed with no problem since it would then only be 8 feet high, 8 feet wide, and 10 feet long, right? This would mean there wouldn't have to be any permits bought, no teams of people following it and no police escort and other such things that makes using a building mover so expensive since it would fit without going over the size restrictions. I did find an 8.5 foot wide by 20 foot long flatbed that can be rented out for one day for $75 at a local rental place, so other than that it would just be the cost of finding people at both ends to help load it on/off which I would think can't be THAT expensive, although I could well be wrong.
No matter what, this is going to be more trouble than it's worth, but again, lesson learned...I'll know better next time.
Old 05-06-2010, 11:06 PM   #21
"First, if I was to disassemble it and then put it on a truck or trailer to be driven back home, approximately what size truck/trailer would I need? "
I may be able to give you some idea, by describing how we moved my daughters shed ( 6 disassembled pcs.)
We couldn't access the rear yard with a truck or trailer. So, with the sections on edge, we used a hand cart at each end. Two people handling the carts and two balancing the sections. My guess is that each section weighed between 200 and 300 lbs.
In your case, you have the floor in addition. I would suggest that the walls would be about 800 lbs. The floor perhaps 300 and the roof 400. For a total of 1500 lbs.
A unit capable of carrying 2000 lbs. would likely be capable.
Keep in mind that this is an armchair guess!
I wonder what others would estimate!
I think that your idea of removing the roof has merit, however you will still have to figure out a way to get 1/2 ton of building, unto the trailer.
Old 05-08-2010, 10:55 AM   #22
Rewards Points: 530
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside)
I moved one of a similiar size years ago. It was on a deck-like surface sitting directly above another building on posts. I disassembled the roof (tin) and seperated the walls intact. Pulled the nails in the decking and beams. Loaded it on a trailer and borught it about 30 or 40 miles and reassembled one block high. It was not sealed and only had 2 small windows. The trailer was an old car hauler. Pulled it home with a small toyoto truck. V6, I think
Total cost..maybe a tank of gas for Toyota b23 (I think) pickup.
I did similiar to what has been described but not with 4 people. I took it apart and lowered the pieces from atopp the the building this was built above on posts going to the ground on the outside of the lower building. I did use a rope in my situation. I took it apart and my mother helped me a little getting the pieces down. I stacked the pieces in my sisters yard. Went back with the truck and trailer. I had to lay the walls with the bottoms in the trailer and the tops on the fender rails. I think my son helped me load the pieces.
When I got it home, I unloaded it and assembled it by myself. I pulled the deck mat off and rebuilt on blocks. I then pulled the walls off the trailer and got thme upright on a pieceof 4' schedule 40 pvc drain pipe, rolled them to the deck, manhandles them onto the deck and nailedthem back together in the corners. I then removed the roofing mat's from the trailer and reassmbled them and used the same tin.
I was in my mid 40's then. Not sure I would attempt it now. Its interesting to think I even did this now.
Even though I did the unloading and reassembling alone, I do not advise doing this alone the way I did. Moving those walls still intact with the siding and all on the pipe was a little precarious to say the least. The weight was not the problem, but it was a pretty good balancing act.
Btw, when I got the walls rolled to the deck, I would have them parallel to the deck then lay them over onto the deck. I then raised them into position, braced and reattached them to one another.
My shed is very much like yours. 8' walls and gable ends. Not counting the deck, I'd say may is maybe 10' from the deck to the ridge
Old 05-08-2010, 05:43 PM   #23
Rent an open top horse trailer ? double wide if you can find it.
Don't tell them what it's for. (should ride low and wheel wells to the outside) ok if some of walls & roof sections sticks out the back... don't forget a big red flag...
Tie down the load like it's the devil. Width? approx 4 - 5" w walls / 2- 7" roof sections / 1 8'x 10' floor section ??? depth?? 34" + gable ends stacked at same spot ? ( +5 " ) so 39" + floor depth? + wiggle room
cause you won't get it in tight..... maybe one horse wide would work????
Floor last on... first off...
This solution should avoid width & height Highway restrictions and allow for easier handling.
have some old pipe for rollers or at least to cut down on friction as you push/slide the wall & roof section in (standing up-right).
Dismantle as advised above & consider:
nail 2x4 a set for each side under the roof rafters ... will help keep them keep tight as sections and provide some carrying handles.. 1x4 on the inside of walls might also help...you might be able to keep walls in rack and leave the windows in place. A plywood cover might help on the windows... above adds to the width...offset added 2by and 1 by supports to interlace packing.
You may want to bring a horse to help ya! Also consider repainting when you are done...
You may have been able to build a DIY 8x10 for the $$'s and time this
is going to cost you...
OP ....Can you cancel the deal and get most of your money back?
Big Bob is offline   Reply With Quote
Old 06-24-2010, 03:55 PM   #24
How to move a small shed
First of all you should call a protable building place and they have special trailers with rollers made to move those buildings. I am not recommending this practice but I have helped move these with a standard 16 foot trailer. You need to jack the build up on one end back the trailer up under as far as you can. Then you can use a comalong to pull the building up and on top of the rails. Place a good amound of grease on the rails and it will help the building slide along. Another way is the jack the building up even obove the trailer rail height and back up all the way under it. It is dangerous either way and I would get a professional to do it. They have the proper tools.
I have a dilemma. I purchased an 8 x 10 wooden shed out of the classifieds which I need transported to my house. The travel distance between the shed and my house is exactly 102 miles. I need a relatively inexpensive way to get it transported from the seller's backyard to mine. Here is a video tour of the shed so you can get an idea of what I'm dealing with:
Sportace1 is offline   Reply With Quote
Old 06-27-2010, 12:20 AM   #25
Rewards Points: 530
I would brace the walls. There is so much glass area in that shed, it is bound to rack when jacking one end and moving.
If I winched it, I would be sure to have stable places to attch the chain/cable. I would also pull each chain/cable in its own plane (straight), unless I put something between the pull points to keep them from collapsing in toward each other.
I would also use a 4" pipe instead of grease. You can roll a pretty good size shed with 4" pvc pipe and big pry bar anywhere you want it.
Old 04-09-2012, 08:13 AM   #26
Rewards Points: 1,294
I would question the dimensions on that thing. I would bet good money that thing is not 12' tall. simply look at the video. If it were indeed 12' tall the windows by proportion would be 6' tall themselves and the door around 8' tall. If you look at the 4x4's that are under the shed and using them for scale (basing the size by comparing to the wheelbarrw wheel which is about 12" diamter) I would say the siding is roughly 5" wide/tall. That give a rough door height of about 6'. I would venture a guess that this thing is nore like 8'-9' tall. did you actually measure this yourself or did you go by the rough guess the seller told you?
danpik is offline   Reply With Quote
Old 04-09-2012, 08:31 AM   #27
joed's Avatar
Rewards Points: 11,598
Try looking at car hauler trailers. The measurements might be closer to what you need.
Old 04-09-2012, 09:12 AM   #28
the Musigician
DangerMouse's Avatar
Has anyone looked at the age of the OP's post?
I'm PRETTY sure his problem has been solved, one way or the other.
DM
The Following 3 Users Say Thank You to DangerMouse For This Useful Post:
BigJim (04-09-2012), jbfan (04-09-2012), kj6887 (04-09-2012)
Old 04-09-2012, 09:14 AM   #29
Electrical Contractor
jbfan's Avatar
Rewards Points: 144
Nice job on the spam DM!
jbfan is online now   Reply With Quote
Old 04-09-2012, 10:20 AM   #30
the Musigician
NP, that's why they pay us the big bucks!
DM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
