Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-07-2010, 08:35 AM   #1
moveable pergola.
Hi, I will try and explain my issue as best as i can. I want to install a pergola outside. The area is about 5m X 4m and in the middle is a hot tub with decking surrounding it out to 3 high walls. I would like a wooden pergola to offer some shade, but the problem is I also want to enjoy full sunlight now and again when in the hot tub. SO i am thinking is it possible to make some kind of drawbridge mechanism so i can pull the pergola up 90 degrees to rest on the back wall, exposing the area to light??. if so does anyone have any good ideas which would look good?
Hope that made some kind of sense??
thanks dave
seagulls is offline   Reply With Quote
Old 01-07-2010, 09:24 AM   #2
moveable pergola.
thanks dave
Why don't you just motorize the top and open it up on hinges? And so you can follow the Sun throughout the day, put the pergola on a motorized merry go round like mechanism.
Take pictures and post them when you're done.
Ron
Old 01-07-2010, 01:47 PM   #3
Household Handyman
moveable pergola.
I build Pergolas in my area, and often use the Internet to find distinct and different than normal designs. My first thought as to what you want is "blinds", yep, the type that cover the inside of windows. I'm thinking that if you use 1x4's or 1x6's, and designed in a manner in which they can be overlapped slightly, then opened when needed. With a pin in the end of each board, and all pins connected, it shouldn't be that hard to open them, manually or by some mechanically means. Good Luck, David
Pergola - can you believe what the building inspector told me Italgrl Building & Construction 30 04-24-2010 12:02 AM
Attached Pergola stubits Building & Construction 5 08-01-2009 02:07 PM
Building a Large Pergola CCE1876 Building & Construction 1 04-28-2009 03:19 PM
Pergola - paint or stain - then maintenance woodsglen Painting 2 07-15-2008 09:30 PM
ledger attached to brick for pergola soupdizzle Carpentry 7 07-07-2008 04:43 PM
