Mounting Shop Lights To Garage Ceiling - Thin Joists? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-27-2011, 08:02 PM   #1
Rewards Points: 37
mounting shop lights to garage ceiling - thin joists?
I was mounting an 8 foot fluorescent fixture to my garage ceiling (using 3/8" eye bolts and S hooks) today. The ceiling is finished (not popcorn but seems similar) and above the garage are bedrooms. I was surprised that my drill bit went very quickly through the joists (felt the bit pass through and then hit open space). I made pilot holes in a few other areas over the joists and found the same thing. I did install the eye bolts and hung the fixture, but wanted to ask if that is sound. The eye bolts aren't as tight as they would be if they were screwed into a solid 2x4, but they don't feel like they would come out. I a second 8' fluorescent fixture to hang as well. Am I OK to mount to whatever these thin joists are?
Edit: I was just doing some Googling, and now I am wondering if that is strapping that I mounted to -- I was not
familiar with strapping. My question still stands.
Pickngrin is offline   Reply With Quote
Old 10-28-2011, 06:20 AM   #2
Not sure what you hit??? If there is a living space above, there should be at least 2x10's above the drywall, or is it wood lath plaster(old House???) And they should be 16" on center unless the house is OLD, in which case thy could be from 16" to about 20".
Old 10-28-2011, 06:59 AM   #3
Rewards Points: 37
The house was built in 1965. I am now thinking that I drilled into the strapping. If that is the case, then the 2x10 joists would be perpendicular to where I drilled, right?
Old 10-28-2011, 06:13 PM   #4
i was thinking you might have engineered I beams, but it could also be strapping...
That's just my opinion. But it's free, so take it for what it's worth to you.
1910NE is offline   Reply With Quote
Old 10-28-2011, 07:04 PM   #5
DIY staff
Rewards Points: 7,174
It's not unusual to have 1x2 furring strips above the drywall----If you are really curious---drill a small hole and insert a piece of bent wire up there ---spin it around and see what you hit.
Old 10-28-2011, 07:40 PM   #6
Rewards Points: 37
This is getting frustrating. I haven't been able to locate any joists and I've got a number of pilot holes drilled that I need to patch. If they are indeed 1 x 2 furring strips, is it safe to hang the eyebolts from those? Doesn't seem too sound to me. Poking a coathanger around didn't really work for me.
Old 10-28-2011, 07:49 PM   #7
DIY staff
Florescent fixtures don't weigh much----consider using molly bolts and hanging directly to the drywall.
Some times thin sheet metal furring is used----
Old 10-28-2011, 09:23 PM   #8
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,242
this pretty much sounds like you drilled through the strapping. if you anchor to the strapping it should be fine if its near the joist. . just a matter of figuring out which direction the strapping is going
based on the age of the house the floor system is definitely 2x8's or 2x10 joists. at first i though it might be tji's or ojt's but they werent being used in the 60's
woodworkbykirk is offline   Reply With Quote
Old 10-29-2011, 05:18 PM   #9
Rewards Points: 37
I figured it out guys/gals. I cut a small square out of the drywall. Funny thing, my last pilot hole was millimeters away from the joist. What had been happening is that every time I felt the bit go through the drywall and into empty space, I assumed I was off target. I didn't realize that there would be a gap between the drywall and the joist. Thanks again for the input.
Mounting to Garage Ceiling stacyjkcmo Building & Construction 12 05-18-2011 04:14 PM
How to finish closet ceiling in garage space bob22 Building & Construction 2 12-18-2010 02:10 AM
garage ceiling joists josh123 Carpentry 6 07-14-2009 11:07 PM
Lights for a garage? stagger19 Electrical 8 01-16-2007 05:58 AM
Spacing of ceiling joists Pineconeman Building & Construction 3 05-13-2005 11:16 PM
