Mounting Ceiling Fan With Old Metal Brace, Need Joist?? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-09-2010, 12:44 PM   #1
Mounting ceiling fan with old metal brace, need joist??
Hi,
Removed an old ceiling fan. The steel junction box was mounted to a metal brace between the support braces, never had a problem with fan wobbling or anything.
It's a flush mount 52", directions keep saying to have junction box mounted on a wood joist. Then to mount bracket to the junction box with 2-3" wood screws.
Would just reusing existing support and hardware be strong enough? Is it common to use the metal support braces?
nimchimpski20 is offline   Reply With Quote
Old 11-09-2010, 01:53 PM   #2
How heavy is the new fan? If its heavy you should be using a fan brace box. What is securing the brace that is there to the beam?
lordlondis is offline   Reply With Quote
Old 11-09-2010, 04:06 PM   #3
The existing metal support rod seems more than sufficient to support the new fan. The old fan was a decent amount heavier. I've decided to just hang it by the junction box as the previous fan was hung.
Old 11-09-2010, 07:18 PM   #4
Just make sure the brace is well secured to the beams with screws and not by nails or staples.
Tags
bracket , ceiling fan , fan , junction box , support
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
install ceiling fan in a suspended metal stud ceiling? amp3d Remodeling 2 09-10-2010 08:55 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 09:00 AM
Large metal "tabs" in openings cut in bi-level rim joist... What are they? Insulate? nutlog Building & Construction 9 11-09-2009 04:19 PM
ceiling joist this old house Building & Construction 2 03-23-2006 10:00 AM
