Morter Crumbling Between Bricks - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-11-2010, 11:31 PM   #1
Morter crumbling between bricks
Hi,
I have a situation where Morter crumbling between bricks. In some places it is so bad that there is almost nothing between the bricks.
I spoke to the local hardware store and they told me that there is a small creature that is causing the morter to crumble and that I will need to spray the area with a strong pesticide and then after that remorter the joints. Does this sound correct? Any feedback will be most appreciated.
Thanks in advance,
Rottaj
rottaj is offline   Reply With Quote
Old 09-12-2010, 06:38 AM   #2
Doubtful, but possible. I have never heard of cement eating critters. But freeze/thaw and a poor mortar mix to start, are usual culprits. Proper pointing requires that the joint is cleaned out at least 1 1/2" deep.
In any case, you definitely need to repoint.
The Following User Says Thank You to Just Bill For This Useful Post:
rottaj (09-12-2010)
Old 09-12-2010, 07:16 AM   #3
steveel's Avatar
I had not heard of such a critter either, but I noticed the OP is in Sydney Australia.... and whaddya know? They have something called a mortar bee. http://www.ausinspect.com.au/mortar bees.htm
I gather the bee's contribution is allowing water back behind the masonry and the water does the major damage.
steveel is offline   Reply With Quote
The Following User Says Thank You to steveel For This Useful Post:
rottaj (09-12-2010)
Old 08-20-2011, 05:16 AM   #4
Hi guys,
I discovered that it was tiny black ants that were responsible for my issue - I got this realy strong pestacide from the hardware store and have treated the brisk work twice and no new damage - so still have to fix the existing but it looks like it solved the usse!
Cheers,
JR
The Following User Says Thank You to rottaj For This Useful Post:
oh'mike (08-20-2011)
How to repair crumbling cement and mortar? jerseyguy1996 General DIY Discussions 14 08-01-2010 10:49 AM
Reclaimed Bricks (repointing) soft? davidwarner Building & Construction 11 05-06-2010 09:56 AM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General DIY Discussions 9 04-11-2010 06:11 AM
Use stone dust under bricks to form a border around flower bed Curious123 General DIY Discussions 4 08-23-2009 03:41 PM
Damp, Crumbling bricks & Blown Plaster crscrs Building & Construction 2 10-02-2008 05:20 PM
