Morter Bed - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-01-2008, 10:14 PM   #1
Morter Bed
We are currently building a basement shower stall. We layed our subfloor in the shower.. we are about to lay the membrane. some quick questions...
Do we need to glue the membrane to the underlayment cement that is layed?
And what is the best product to use as the morter bed that goes over the membrane? we shop at lowes,
How long after we lay the morter bed until we can lay the thinset and tile?
Thanks for your help...
Demochick is offline   Reply With Quote
Old 03-02-2008, 01:35 PM   #2
Tile Contractor
Bill_Vincent's Avatar
First things first-- explain what you mean by "we layed our subfloor in the shower..."? Also, what are you using for a membrane?
"Whether you think you can, or you think you can't, You're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline   Reply With Quote
Old 03-02-2008, 08:22 PM   #3
Well we used the underlayment cement and we sloped it...we are using the pvc rubber membrane..that lowes has.. we just didnt know if we used regular mortar..lowes says yes....but i thought we used portland cement and sand...now im just confused..
Old 03-02-2008, 09:12 PM   #4
Tile Contractor
I'm impressed!! I don't know who told you about doing a preslope, but it's not often that I run across a DIYer who knows to do that, which is why I had to ask!! kudos to you!!
Also, you're right-- you don't want a regular mortar mix, that what you want now is a sand and cement mix. your best bet is to use a bagged sand mix, which can also be found at Lowes. Only wet it down to the point where it looks and feels like damp sand, and then scread it off from there. Also, to answer your original question, no, you don't need to adhere it. Set it in, and nail it at the top of the memrbane, which should be about 10" or so off the floor.
Here-- I'm going to give you a link that explains in detail just how to do what you're doing right now:
http://www.ontariotile.com/preslope.html
Old 03-03-2008, 06:52 AM   #5
Well, thank you..
So I should use the portland cement and sand mix...what consistancy to I mix it too.
I get confused because I tend to google EVERYTHING.. lol, and when i googled this subject i seem to get things that dont match 100% with each other so I havent come across a sure way to do it..
also...is it ok to use 100% silicone caulk around my patches for extra security..i just want to feel confident that its not going to leak..the glue I just used..made me feel really crappy and it didnt stick like i feel it should have..
thanks again...I have some time for responses now becasue my husband just left for tennessee so he wont let me do much while he is gone..id like to have this figured out by friday when he returns...and feel confident about what im doing thanks again...
Shanon
Old 03-03-2008, 08:02 AM   #6
Tile Contractor
Ummmmm.... patches? Where are these patches?
As for consistancy, like I said above-- about the consistancy of damp sand. Seriously-- check out that url I gave you. It's going to answer most of your questions.
Old 03-03-2008, 08:57 PM   #7
corner patches.
.and i did read your url link its a great help...ill post pics tommorrow and you can let me know what ya think..
Concrete Shower Pans??? seaturtle General DIY Discussions 10 01-21-2008 03:26 PM
morter bed? boman47k Remodeling 3 09-07-2007 01:56 PM
Floor Prep for Tile Floor etopf Flooring 2 09-05-2006 09:32 PM
