Mortar And Grout Down The Bathtub Drain... - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-04-2011, 10:35 PM   #1
Mortar and grout down the bathtub drain...
I am currently putting the finishing touches on my recently redone bathroom, which, of course, means I'm working out a few "kinks." We retiled the floor and a member of my household had the brilliant idea to clean up the grout and mortar in the bathtub and pour the excess down the drain. As you can imagine, the drain is pretty slow now, and drain-o isn't doing the job. I'm really hoping I don't have a huge plumbing project on my hands...is there any way (or anything) to fix this? Please help!
Alyssaz is offline   Reply With Quote
Old 10-05-2011, 06:15 AM   #2
DIY staff
Rewards Points: 7,174
You might get lucky and be able to snake the tub drain by removing the overflow cover.
If that fails---it's time to remove the P-trap ---
Old 10-05-2011, 06:46 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Once saw a tile contractor do that on a new commercial job. The plumbers cut the new galvanized drain lines apart to find them 3/4 full of solid grout. The owner wouldn't approve using Fernco's so they had to take everything apart and replumb it. Different tile crew showed up for the rest of the job.
Muriatic acid?
The Following User Says Thank You to Maintenance 6 For This Useful Post:
gregzoll (10-05-2011)
Old 10-05-2011, 08:31 AM   #4
Concrete & Masonry
Rewards Points: 582
Originally Posted by Maintenance 6 View Post
Muriatic acid?
We've had use it in the past when some concrete slurry got down a drain..........
I would start with a 10:1 mix, assuming the entire plumbing line is pvc not metal of any kind, vent the room well and rinse the drain well for several minutes afterwards.
jomama45 is online now   Reply With Quote
Old 10-05-2011, 08:44 AM   #5
DIY staff
If you try this ---protect all chrome finished with a thick coating of grease first---
Old 10-05-2011, 11:12 AM   #6
Thanks, everyone! I will try all of the above.
Old 10-05-2011, 01:31 PM   #7
Rewards Points: 526
Muriatic acid is nasty - it is highly concentrated hydrochloric acid. I would NOT use it inside and I would not pour it down the drain. I am not even sure it would work. It etches masonry, it does not dissolve mortar.
Windows is offline   Reply With Quote
Old 10-05-2011, 01:42 PM   #8
Do you have any other suggestions? I am pretty new at this home renovation stuff. Having just completed my bathroom, I would rather not rip out the tub to replace the p-trap.
Old 10-05-2011, 02:20 PM   #9
DIY staff
Tell us about the tub and any access to the plumbing---
The P-trap might be easiest to reach from below---unless you are on a slab.
Or from the wall behind the mixer/drain-----I'm pretty sure you will not need to touch the tub or tube work.
Post a picture---we are quite inventive----and most of us are very experienced in fixing little screw ups like this one.
A location would help.
Old 10-05-2011, 02:56 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If it was swept into the the drain it is likely in small pieces that have become lodged by friction in the trap. Remove the strainer and poke around with a clotheshanger then use a shop vac and suck it out of there. It should basically come out the same way it went in - in pieces.
Remove the filters first because you are going to be sucking water out of the drain at the same time. If you have any drain cleaners down there BE CAREFUL.
Next question?
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
Mortar or Grout ? jukejoint Building & Construction 1 08-25-2010 06:03 AM
Grout lines in shower floor cracked and mortar is oozing out. megg Flooring 2 03-30-2010 06:35 AM
My grout is crying Whatthe??? Building & Construction 2 09-02-2009 01:20 PM
Sealing Grout qvminich Building & Construction 4 08-24-2008 05:56 PM
