-   -   Mortar and grout down the bathtub drain... (http://www.diychatroom.com/f2/mortar-grout-down-bathtub-drain-119258/)
Alyssaz 10-04-2011 10:35 PM
I am currently putting the finishing touches on my recently redone bathroom, which, of course, means I'm working out a few "kinks." We retiled the floor and a member of my household had the brilliant idea to clean up the grout and mortar in the bathtub and pour the excess down the drain. As you can imagine, the drain is pretty slow now, and drain-o isn't doing the job. I'm really hoping I don't have a huge plumbing project on my hands...is there any way (or anything) to fix this? Please help!
oh'mike 10-05-2011 06:15 AM
You might get lucky and be able to snake the tub drain by removing the overflow cover.
If that fails---it's time to remove the P-trap ---
Maintenance 6 10-05-2011 06:46 AM
Once saw a tile contractor do that on a new commercial job. The plumbers cut the new galvanized drain lines apart to find them 3/4 full of solid grout. The owner wouldn't approve using Fernco's so they had to take everything apart and replumb it. Different tile crew showed up for the rest of the job. :laughing:
Muriatic acid?
jomama45 10-05-2011 08:31 AM
Originally Posted by Maintenance 6 (Post 742527)
Muriatic acid?
We've had use it in the past when some concrete slurry got down a drain..........:(
I would start with a 10:1 mix, assuming the entire plumbing line is pvc not metal of any kind, vent the room well and rinse the drain well for several minutes afterwards.
oh'mike 10-05-2011 08:44 AM
If you try this ---protect all chrome finished with a thick coating of grease first---
Alyssaz 10-05-2011 11:12 AM
Thanks, everyone! I will try all of the above. :)
Windows 10-05-2011 01:31 PM
Muriatic acid is nasty - it is highly concentrated hydrochloric acid. I would NOT use it inside and I would not pour it down the drain. I am not even sure it would work. It etches masonry, it does not dissolve mortar.
Alyssaz 10-05-2011 01:42 PM
Do you have any other suggestions? I am pretty new at this home renovation stuff. Having just completed my bathroom, I would rather not rip out the tub to replace the p-trap. :(
oh'mike 10-05-2011 02:20 PM
Tell us about the tub and any access to the plumbing---
The P-trap might be easiest to reach from below---unless you are on a slab.
Or from the wall behind the mixer/drain-----I'm pretty sure you will not need to touch the tub or tube work.
Post a picture---we are quite inventive----and most of us are very experienced in fixing little screw ups like this one.
A location would help.
Bud Cline 10-05-2011 02:56 PM
If it was swept into the the drain it is likely in small pieces that have become lodged by friction in the trap. Remove the strainer and poke around with a clotheshanger then use a shop vac and suck it out of there. It should basically come out the same way it went in - in pieces.
Remove the filters first because you are going to be sucking water out of the drain at the same time. If you have any drain cleaners down there BE CAREFUL.:)
Next question?:wink:
