Mortar Or Concrete Basement Patch Form? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-30-2012, 07:39 AM   #1
Mortar or Concrete basement patch form?
My basement is a old stone rubble foundation and there is a spot that is abot 2ft x 3ft that has slightly eroded because of poor landscaping and the lack of gutters before I purchased the house. I cleaned out the dirt and clay that was seeping in and built a form in front that extends abot 3 inches out from the wall. I am going to fill it with either concrete or mortar and paint it with drylock when it dries. What is better to use in this case? Concrete or Mortar?
bansheex is offline   Reply With Quote
Old 01-30-2012, 08:43 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,088
Ayuh,.... Get rid of the form, 'n trowel on stiff mortar...
Bondo is online now   Reply With Quote
Old 01-30-2012, 12:34 PM   #3
By stiff mortar do you mean regular mortar mixed thick with little water? Thanks for the quick reply.
Old 01-30-2012, 12:41 PM   #4
concretemasonry's Avatar
Rewards Points: 2,594
The Drylock may not be needed since it just another paint type material.
For coating concrete repairs and maintenance, Thoroseal is superior and is very good and has been used for decades because it is cement based. The problem is that you area is so small you will not be able to use it unless you have friend that has a bag open and will give you a pound or so.
Dick
concretemasonry is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Condensation on concrete floor under basement fiberglass shower/tub insert bsande2 Building & Construction 2 01-22-2012 07:02 PM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Basement Wall Mortar rory535 Building & Construction 16 08-06-2009 09:39 AM
