Morso Wood Stove - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-03-2011, 02:22 PM   #1
morso wood stove
hi.. I'm looking at a used morso woodstove with a baffle top.. anyone used one of these or knows how well they work? thanks
ldstrick9 is offline   Reply With Quote
Old 01-09-2011, 04:04 PM   #2
morso wood stove
I don't know the Morso stove, but I do heat only with wood. I have 2 other modern epa cert stoves. If you have burned with older stoves, you will be pleased with the wood savings of the air-tight stoves. However, they do require a slightly different approach.
1. wood must be well seasoned
2. burn in full cycles - load it up and let it burn down to coals before reloading
3. as your fire gets going, cut the air back in increments. This is important to maximize heat output. As you cut the air back, you stack temp will drop, but your stove top temp will climb and the efficient secondary combustion will kick in. Enjoy the light show.
OffRoadAudio is offline   Reply With Quote
The Following User Says Thank You to OffRoadAudio For This Useful Post:
ldstrick9 (01-09-2011)
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
New Wood Stove tuchodi Green Home Improvement 3 01-18-2011 06:12 PM
Wood stove and metal roof problem mesquitemagnoli Roofing/Siding 6 12-20-2010 08:56 AM
Installing a Wood Burning Stove / Fireplace ddrowe0217 HVAC 3 11-27-2008 04:48 PM
Wood Burner, run stove pipe through floor awalker19 HVAC 7 10-19-2008 10:28 AM
