Molding In Shower..wall Cracking! - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-12-2009, 10:58 PM   #1
Molding in shower..wall cracking!
Hi guys; I'm new here. Anyways here goes:
Noticed some cracking in the shower wall with warped paint...tore it back and Voila! Decent amount of rot about 4" up in the drywall. No green here. It is a prefab shower and I'm looking to replace the walling around it with something that will be more reliable than its predecessor.
I've heard bad things about Greenboard obviously; looking to avoid that. I hear 1/2" cement board is the way to go. Anything I should know before going ahead with this? My first time doing shower repair. Thanks.
Pleasuremann is offline   Reply With Quote
Old 04-13-2009, 06:01 AM   #2
Not quite sure what you are describing. Is it tile or something different, a surround?? Yes, greenboard is not what it was originally intended. Ok for walls out side the shower, but not under tile in the shower/tub area.
Old 04-13-2009, 02:22 PM   #3
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
Pictures
We can not see what you are working on. Pictures please. Dorf Dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 04-13-2009, 03:01 PM   #4
Registered User
Rewards Points: 5,516
I think it may be the wallboard above the shower surround. I'd replace it with Denshield, with a waterproof face. Not cement board, unless you want to Redgaurd. Even then c.b. wicks water. Be safe, GBAR
Old 04-19-2009, 09:47 PM   #5
I don't have a working camera right now but I can describe.
The shower itself is a prefabricated one-piece shower/bath. There are no tiles anywhere in the bathroom. My problem became evident when I noticed that there was some cracking and general warping of the paint in the areas where the top of the prefab shower unit met with the walls, where it had been caulked. I peeled back some of this paint and found crumbling drywall.
The content of the wall which appears to be constant throughout the bathroom goes in this order:
1. Finish
2. Primer
3. Thin brown paper
4. Drywall
5. Thin brown paper
6. Studs/crawl space
Of course, the only difference is where the caulk has been applied around the prefab unit to (attempt to) keep moisture from getting to the drywall.
Once again, there are no tiles in this bathroom. I just found molding, crumbling drywall behind some coats of paint and a couple of sheets of brown paper where it was obvious moisture damage had been getting to it, surrounding the top perimeter of a single prefabricated shower/bath unit.
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 12:05 PM
Shower floor grout cracking radnrs Flooring 11 09-14-2008 08:49 PM
Would you trust Sharkbite for Shower, Dropear behind wall? twilightcall Plumbing 11 08-22-2008 09:11 AM
Cracking Grout Between Shower Tiles average General DIY Discussions 9 05-08-2007 02:20 PM
