Mold Problem? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-20-2010, 01:17 PM   #1
Mold problem?
I noticed that there was some discoloration and puffiness in the drywall next to the tub in our master bath. I peeled off a little bit of the drywall to see if there was anything going on underneath and I think I've found some mold. The caulking that goes around the tub where it meets the "fake" (plastic tub/tile kit) tile is all molded too.
I took some pictures...
http://www.kyndoutdoors.com/_resized_DSC02560.jpg
http://www.kyndoutdoors.com/_resized_DSC02561.jpg
http://www.kyndoutdoors.com/_resized_DSC02562.jpg
Can you please tell me if I have a problem here and if so, how bad? What steps do I need to take to resolve the problem?
id3ma is offline   Reply With Quote
Old 02-20-2010, 01:36 PM   #2
ccarlisle's Avatar
Well, not a major problem but a problem that will continue to get worse unless you do something about it. There wasn't enough caulk put between the tub and the wall, so water collected there (proabably went through and down) and has channelled along the tub to the wall.
You'll have to scrape it all out, treat it with bleach, let it dry then recaulk it with 100% silicone caulk. The scrape/sand the wall, spray on some bleach (10% solution) till all mould signs are gone, reprime then repaint .
If you use a shower curtain, make sure it stays inside the tub right around the bend til it meets the taps and spout. But the caulking should prevent any more water from leaving the tub.
The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,
ccarlisle is offline   Reply With Quote
Old 02-20-2010, 01:52 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
id, Welcome to the Forum.
Thanks for posting the pics.
Post #2 has good advice
Also an old toothbrush is good for helping to clean out that bottom crevice
Disclaimer
& Stay Safe
.....Bob Lavery
Tags
bathroom , mold , shower , tub
Mold problem after unfinished house was closed in for the winter... lemonbltz Building & Construction 28 12-30-2011 08:52 PM
Kenmore (Whirlpool?) Ice maker problem reddog6 Appliances 4 10-09-2011 07:11 AM
Mold on framing of bathroom wall CowboyAndy Remodeling 34 10-22-2010 07:53 AM
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 02:46 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
