Mold On New Deck? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-14-2012, 08:02 PM   #1
Mold on new deck?
I have a 1-year old deck, pressure-treated pine, which I stained 3 months after construction. Now I see a lot of areas that are discolored (black) which can only be growths of mold.
Can that be the case, so soon? I think I may have stained it too thin in areas, because where I edged (perhaps thicker), they don't appear. Also, important to note that it only appears in the areas that are exposed to sunlight. The bottom deck that has the top deck as a roof does not have the growth (which I would have thought to be the opposite).
Do you think maybe the thin layer of OIL BASED stain could be the culprit?
I also have applied Mold Armor and scrubbed it with a hard-bristle brush, and now the deck in these areas looks pretty white (almost like I scrubbed the stain off of it).
Any help appreciated. Could it be something other than mold??
Thanks!!!
derekmanderson is offline   Reply With Quote
Old 09-14-2012, 08:04 PM   #2
is this particular spot under a tree? if yes, falling leaves can stain your wood (speaking from my personal experience).
allthumbsdiy is offline   Reply With Quote
Old 09-14-2012, 08:25 PM   #3
Thanks, good call but no, it's out in the open.
Old 09-14-2012, 08:30 PM   #4
Rewards Points: 14,312
Always best to include where you live in your profile, so people do not have to keep asking.
In your case it will be to try and see if you let it dry long enough.
Tags
mold deck stain
mold on the bottom side of the roof deck overhang mark faultersac Painting 4 09-30-2011 12:52 PM
Mold found - unsure what to do?? izzyant88 General DIY Discussions 12 06-17-2011 06:21 AM
Deciding on replacing deck or enclosing maj0819 Building & Construction 4 03-23-2011 02:43 PM
Fasten deck board from under deck resonator Carpentry 14 09-20-2010 10:15 AM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 05:07 PM
