Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 09-23-2010, 08:57 PM   #1
Is this Mold in my Garage
...and if so should I be concerned about it?
http://img814.imageshack.us/img814/563/43416662.jpg
http://img375.imageshack.us/img375/2072/12306190.jpg
I bought the home recently, and the garage has a hose attachment on the inside to (I assume) wash the car in the winter. This is clearly some type of water splashing, but is this mold and what do I need to do about it?
It goes around the entire base of the interior of the garage.
(The garage is attached to the house. The house was built in 1980.)
Thanks!
yellowhouse is offline   Reply With Quote
Old 09-24-2010, 07:05 AM   #2
I don't see mold, but the plywood has obviously been wicking up water from the floor at some time. Ideally, plywood, drywall etc., should not touch the floor for this reason.
Old 09-24-2010, 10:10 AM   #3
concretemasonry's Avatar
I agree with Bill - It is unfortunate that the plywood was hung so low, especially since you have a concrete block supporting the framing. It at least is is better than the sill sitting on the slab.
You could just let it stay as long as you can stand it and it is functioning. Eventually, you can expect some mold and serious rotting in the future.
As a fix, remove the plywood and search for a more suitable material and hang it higher. If you are lucky, you will have 8" high block and not just 4" high.
Dick
concretemasonry is offline   Reply With Quote
Old 09-25-2010, 12:23 AM   #4
I agree with them. I don't think that's mold. It's more of a water mark. I wouldn't worry as of the moment as it is still in good condition. Make sure to check on it from time to time.
MagicalHome is offline   Reply With Quote
Old 09-25-2010, 07:18 AM   #5
I would cut it back so that you don't have to replace all of it in the future.
1910NE is offline   Reply With Quote
Tags
garage, mold, moldy wood, plywood walls
mold in garage coeng Painting 6 05-01-2013 05:51 PM
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 11:21 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 02:46 PM
Concrobium or White Vinegar? eis61374 Remodeling 8 11-17-2008 07:56 AM
