Mold Or Dirt? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-30-2012, 05:02 PM   #1
Mold or Dirt?
Can anyone identify if this is mold or dirt from this picture, I am in the process of painting my house and when I removed my fridge this is what I found.
mike27bk is offline   Reply With Quote
Old 12-30-2012, 05:31 PM   #2
Rewards Points: 13,712
Most likly both since it's in a nice warm spot that never gets enough air flow or cleaning.
Old 12-30-2012, 05:32 PM   #3
Is it anything to be concerned about? or should I just clean it and paint over it?
Old 12-30-2012, 05:55 PM   #4
I'd just degrease it, wipe it down with a mild bleach and water, prime and repaint.
Old 12-30-2012, 11:24 PM   #5
Rewards Points: 956
thats mold. whats behind the wall?
federer is offline   Reply With Quote
Old 12-31-2012, 08:54 AM   #6
Rewards Points: 5,974
This shows up a lot behind fridges it is most likely mold. I have had a couple who have had it tested and it came back just a common mold that can be cleaned. But that does't mean that that is what yours is. Personally I would scrub it with bleach water let it totally dry and go on. I don't know if then putting a moldicide in your paint will help or not. You could pull the fridge out say once a month and wash the area with a weak bleach solution and maybe keep it from happening.
Old 12-31-2012, 04:14 PM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,634
Both.
What is behind that wall?
Mild mildewicide and water will clean it off. Prime and re-paint.
Old 01-03-2013, 04:01 AM   #8
I have just got rid of my old fridge and found exactly the same :S
Click Plastics is offline   Reply With Quote
Old 01-03-2013, 06:29 AM   #9
Mold!! Let's kill it!
Rewards Points: 2,012
The picture shows what looks like a bunch of small independent mold colonies. Most likely caused by a lack of airflow, and a supply of dust to feed on. A wipedown with a fungicide will take care of it. Something like Tilex or Lestoil will fix it in short order. Pulling the fridge out and wiping down the wall occaisionally will prevent them from growing from colonies into thier own third world country.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
ToolSeeker (01-03-2013)
Old 01-04-2013, 07:28 PM   #10
Registered User
Rewards Points: 5,514
The refrigerator is a moisture source when they condense the water vapor as part of the cycle, bound to get some on the wall. Check under/behind for lint/dirt build-up on the coils.... use a flashlight---- when wife is not around.OR, while cleaning, announce- "It was time for the annual cleaning under there".
Gary
Dirt floor conditioned crawlspace with horizontal 80% furnace, and mold remediation WillK General DIY Discussions 0 04-29-2012 10:20 PM
Mold or Dirt? Scully General DIY Discussions 7 04-07-2012 09:29 AM
Mold found - unsure what to do?? izzyant88 General DIY Discussions 12 06-17-2011 06:21 AM
mold in crawlspace on dirt b_corwin General DIY Discussions 3 09-19-2009 07:54 PM
Concrobium or White Vinegar? eis61374 Remodeling 8 11-17-2008 06:56 AM
