Mold Behind Wood Panelling - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-02-2009, 03:41 PM   #1
mold behind wood panelling
previous home owner put wood panelling in our basement 30 years ago. The basement has been leaking for years from rain getting in (we plan to fix that problem) I just wonder does anyone know if mold is a problem if it's behind the wood panelling? I cleaned some off of the front part with bleach after our last flood. I'm sure behind it has grown very thick. Just wonder if we should worry about it.
annie68164 is offline   Reply With Quote
Old 04-02-2009, 03:52 PM   #2
Remodeling Contractor
Yes it is a major health problem. And is very common since even building codes required the incorrect method to finish basement walls. Much science has not addressed this. You need to remove all the paneling and dispose of it. Remove and dispose of all the insulation. Clean the studs with water and bleach. Wear a mask and gloves. Read more on how to do a basement finishing properly.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Concrobium or White Vinegar? eis61374 Remodeling 8 11-17-2008 06:56 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
Covering Wood panelling peggy General DIY Discussions 6 10-08-2005 09:55 PM
