Mold Behind Insulation - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-11-2009, 12:10 PM   #1
mold behind insulation
hi guys, i have a little question. i had one wall unfinished with just insulation and no vapourbarrier for most of the winter. just now i want to finish the wall up and notice balck mold behind the insulation. i checked behind another wall that had the vapour barrier and no mold. this is because of the vb not being up and condensation happening right?? what should i do before closing up the wall now?
boddah is offline   Reply With Quote
Old 04-11-2009, 12:28 PM   #2
You need to kill the mold and, possibly, replace the damaged insulation if you cannot remove the mold from it. Make sure the area is dry before adding the vapor barrior and closing up the wall. A mixture of bleach and water works well on hard surfaces for killing the mold, but I don't think it would work on the insulation.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 04-11-2009, 12:43 PM   #3
Registered User
Rewards Points: 5,240
Exactly as Majakdragon said. Use only a 10% beach solution, otherwise it's not as effective.
Very good reading: http://www.buildingscience.com/docum...gs?full_view=1 Be safe, GBAR
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
2lb. closed-cell insulation over joist mold? Jed Lukewater Remodeling 6 02-24-2009 07:59 AM
Concrobium or White Vinegar? eis61374 Remodeling 8 11-17-2008 07:56 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
