mold behind insulation
hi guys, i have a little question. i had one wall unfinished with just insulation and no vapourbarrier for most of the winter. just now i want to finish the wall up and notice balck mold behind the insulation. i checked behind another wall that had the vapour barrier and no mold. this is because of the vb not being up and condensation happening right?? what should i do before closing up the wall now?
You need to kill the mold and, possibly, replace the damaged insulation if you cannot remove the mold from it. Make sure the area is dry before adding the vapor barrior and closing up the wall. A mixture of bleach and water works well on hard surfaces for killing the mold, but I don't think it would work on the insulation.
Exactly as Majakdragon said. Use only a 10% beach solution, otherwise it's not as effective.
Very good reading: http://www.buildingscience.com/docum...gs?full_view=1 Be safe, GBAR |
| All times are GMT -4. The time now is 07:33 AM. |
