Mold In Attic? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-15-2013, 01:37 PM   #1
Mold in Attic?
I'm having concerns i may have mold in my attic. What maybe the cause of the problem is that I installed wooden soffits around my 1940s home and it may not be vented properly. I used the 4 inch round soffit vents I bought from Home Depot and I installed each one along where the screen vents were going into the attic. When I had my roof replaced ten years ago I had ridge vents put in and I notice I get a lot of outside debris in my attic. I'm really concerned to the point that I'm going to take down the soffits I put in.
I"m not completely sure its mold but it has increased over the last several months. I'm getting a black powdery substance along the roof rafters and today I noticed a few areas that have a white powdery substance.
Also my bathroom vent is vented through the roof....Please help.
Uncle Dave is offline   Reply With Quote
Old 02-15-2013, 06:08 PM   #2
Rewards Points: 13,300
Got some pictures?
Sure the vents are not blocked up with insulation?
Would have been a whole lot better to have used larger vent in the soffit.
Hit that black stuff with some bleach and see what happens.
Old 02-15-2013, 07:39 PM   #3
MarginallyQualified
Rewards Points: 2,464
Few houses have enough attic ventilation.
Old 02-16-2013, 05:28 PM   #4
Old 02-16-2013, 05:32 PM   #5
I was able to take some pictures. To me it looks like mold and Im getting really concerned about it. I was hoping if I remove the soffits I put up it would resolve the problem?
I did spray a couple of areas with water/bleach and didnt really notice a change.
Old 02-16-2013, 05:36 PM   #6
747
registered
747's Avatar
Rewards Points: 534
go to dollar store and buy some tilex mold and mildew remover. You will find it in the clean your bathroom section of store. Spray it on. If its mold it will disappear in 15 minutes. Its around 3 dollars for a spray bottle of it.
747 is offline   Reply With Quote
Old 02-16-2013, 05:52 PM   #7
Is there enough insulation? Excessive her loss and insufficient venting are the two biggest causes of moldy attics. Usually combination of both.
gogetter is offline   Reply With Quote
Old 02-16-2013, 07:19 PM   #8
I do need insulation...bad. You can probably tell by the pictures. I put the soffits in myself about 3 months ago and not long after that's when the problem started.
I took some of the soffits down today hoping it will slow down the process.
I will remove the others on Monday.
Old 02-19-2013, 02:22 AM   #9
Rewards Points: 626
first off you live in Florida humid conditions closing off the ventilation to the attic is what is causing this. you choked the air flow down and You need R 49 for your attic. when you put it in make sure not block or restrict the air flow for your attic.
Nailbags is offline   Reply With Quote
Old 03-11-2013, 08:25 AM   #10
greetings from Bolivia
harrymontana's Avatar
Send a message via Skype™ to harrymontana
just use chlore (the stuff you clean your toilet with) and the mold dies and fades away.
For the moisture, it has to come from somewhere,
either some drainage problem and/ or lack of ventilation.
The mold is just a sympthom, you need to get into the moisture issue, why there is moisture
harrymontana is offline   Reply With Quote
Old 03-11-2013, 03:13 PM   #11
Mold!! Let's kill it!
Rewards Points: 2,012
Yep. Looks like typical mold that will form on rafters in an undervented attic. Now that you have it, correcting the ventilation issue will cause it to go dormant, but not kill it. If you are really concerned about it, the only way to get rid of it now, is to scrub it off. Some detergent solution in a spray bottle and a scrub brush, then wipe up everything. Don't just scrub it off and let it drip down into your insulation. Dead mold carcasses can be as allergenic as live ones. After you clean it all, then spray it with a fungicide if you feel the need.
Old 03-12-2013, 10:27 AM   #12
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,928
+1 to the other feedback.
Seal up the top plates, clean the mold, and blow in R-50.
Make sure the soffits are unobstructed and you don't blow them covered.
Old 03-13-2013, 12:08 PM   #13
Special User
Rewards Points: 1,230
You probably just need more soffit vents. See if you can find out the Net Free Vent Area of your brand of ridge vent, and then install at least that amount of net area in soffit vents. Should be no problems then.
Don't forget baffles to keep insulation from clogging the vents!
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 03-13-2013, 01:58 PM   #14
why did you close off the soffit's in the first place? second if it is the problem then take the soffits off. problem soloved.
RTC_wa is offline   Reply With Quote
Old 03-13-2013, 04:08 PM   #15
Registered User
Rewards Points: 5,216
4" screened/louvered round vents have a NFVA of 4", you need two and one-quarter (2-1/4) for each foot of soffit (for 1/150)... could be the problem.
https://ventmastersstore.com/shop/4-...ill-p-123.html
Gary
Mold problem after unfinished house was closed in for the winter... lemonbltz Building & Construction 28 12-30-2011 08:52 PM
Mold found - unsure what to do?? izzyant88 General DIY Discussions 12 06-17-2011 07:21 AM
Attic mold? venting into attic? therompster HVAC 4 06-03-2011 07:18 PM
Attic Mold Rhizando General DIY Discussions 20 03-19-2011 09:07 PM
Attic Mold - Correct Ventilatoin michelle239 Roofing/Siding 3 03-02-2011 05:49 PM
