Moisture Mix? - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-03-2013, 05:14 PM   #16
Rewards Points: 528
Will vapor diffusion be a factor .it was super moist for a while . And can I get fungi or mold growth from no airflow ..it was so moist before that some of the insulation had condensation before I aired it out/dehmudified.no ac flow either.
hidden1 is offline   Reply With Quote
Old 08-03-2013, 06:55 PM   #17
An old Tradesmen
Rewards Points: 6,462
If you seal the vents and run a dehumidifier. Keep it 55%RH or lower. You won't have a mold or fungi growing problem. Unless its already there.
Some people put a small fan in the crawlspace to move the air around so the air the dehumidifier conditions is spread equally through out the crawl.
Old 08-05-2013, 01:28 PM   #18
Registered User
Rewards Points: 5,204
The air won't be circulated as much with a dehumidifier alone, IMO. If you are showing signs of moisture depositing on the joists now, with vents, closing them will reduce the moisture as well as reduce air currents. The temperature difference between outside air and floor is a major factor; Fig. 3, 4: http://www.buildingscience.com/docum...bout-diffusion You need to decide if a closed crawl is for you and act on it after removing other water sources as said.
Closed vents will reduce air movement (ability to transport water vapor), another option is foamboard on the joists to eliminate the condensing surface temperature difference; Fig. 7; http://www.buildingscience.com/docum...n-crawlspaces/
Enter your 55%RH and your floor temp in the graph at Figure "A" to check if safe or not.
Gary
What Is Bathroom Ceiling Moisture Problems evalewis Kitchen & Bath Remodeling 0 07-25-2012 05:26 AM
High moisture in slab, should I put down a barrier for travertine? help! eezeekial Tiling, ceramics, marble 15 11-21-2011 06:14 PM
Cleaning brush StevenH Painting 19 02-06-2011 12:13 AM
Basement Moisture, what's this? bergerdude Building & Construction 1 06-11-2010 02:27 PM
Moisture mystery in midst of shower redo Hisgirl Remodeling 3 01-05-2009 10:29 AM
