Moisture Mix? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-30-2013, 01:06 PM   #1
Rewards Points: 168
moisture mix?
What the best combo mix to make to put in crawlspce to help w absorbing moisture and humidity.there's many types of calciums and cabonates,to salts and even charcoal,am looking to make a big batch but not sure best mix ..
Any ideas for a good batch?
Those little ones with a few pellets won't cut it.
hidden 1 is offline   Reply With Quote
Old 07-30-2013, 01:13 PM   #2
Ventilation transports moisture very effectively and never wears out nor saturates.
Pro Painter is offline   Reply With Quote
The Following 2 Users Say Thank You to Pro Painter For This Useful Post:
concretemasonry (07-30-2013), joecaption (07-30-2013)
Old 07-30-2013, 04:00 PM   #3
Rewards Points: 168
Vents are open w dehumidifier going..the additional mix can help in areas far from dehumidifier though.those damprid containers fill fast.
Old 07-30-2013, 04:17 PM   #4
Can you judiciously locate a small fan or two to move air in a deterministic manner from the stagnant areas to the in/out airflow path? Dehumidifiers sound illogical where there is ventilation.
Depending on where the unwanted humdiity is coming from, there are often paints or coatings that can act as effective moisture-diffusion-barriers, and prevent excess moisture intrusion in spaces one is trying to protect.
Old 07-30-2013, 04:19 PM   #5
Rewards Points: 13,300
Just not going to work.
What will work is keeping the moisture from getting in there in the first place on the outside.
Adding a sump pump is often needed as well as a vapor barrier.
Old 07-30-2013, 04:45 PM   #6
Mold!! Let's kill it!
Rewards Points: 2,012
Dessicants absorb moisture. In a crawlspace, the idea is to remove moisture, not deliberately attract it. Trying to dehumidify a space by using dessicants without first controlling the entry of the moisture is just wasting money. Put some poly on the floor and a low velocity fan exhausting the space. It will get you more bang for your buck.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
MTN REMODEL LLC (07-30-2013)
Old 07-30-2013, 09:59 PM   #7
Rewards Points: 168
Black plastic/barrier is there. Had fan going too..outside humidity accumulates on plastic..
There are less vents for circulation since someone put addition on it,before me...less airflow circulating
I'll look at attic type fans for more circulation .
Old 07-31-2013, 06:37 AM   #8
Then why not just add more vents?
Old 07-31-2013, 05:06 PM   #9
An old Tradesmen
Rewards Points: 6,548
Seal the vents. Then you won't have all the humidity coming into the crawlspace.
The Following User Says Thank You to beenthere For This Useful Post:
concretemasonry (07-31-2013)
Old 07-31-2013, 11:11 PM   #10
Registered User
Rewards Points: 5,216
Where are you located?
If you do seal the vents, add an air supply as said already; http://www.buildingscience.com/docum...ance-and-codes
Gary
Old 08-01-2013, 04:30 AM   #11
An old Tradesmen
Gary
If a supply is added, then a return has to be added. or else the the house is depressurized, and draws in unconditioned fresh air.
Nice link Gary, thanks.
Old 08-02-2013, 04:47 PM   #12
Rewards Points: 168
I'm in Tennessee so it does get a bit humid..right now its reading 55 as to humidity in crawlspace ..is that a good reading ?
dehumidifier on w PVC pipe drain working well.
Old 08-02-2013, 09:22 PM   #13
An old Tradesmen
55% is ok. Sealing the vents will enable you to gt it lower. remember, the humidity in the crawlspace will infiltrate into your house. So the lower you get the crawlspace humidity, the lower it will be in your house.
Old 08-03-2013, 11:39 AM   #14
Rewards Points: 528
I'll seal em but
I thought in the summer they were to be open an closed in winter?
Other factor that may effect level is that central ac isn't working and ductwork is in crawlspace .
hidden1 is offline   Reply With Quote
Old 08-03-2013, 11:55 AM   #15
An old Tradesmen
Opening them in summer, just makes the crawlspace warm/hot, and high in humidity. Keep them closed 24/7/365
What Is Bathroom Ceiling Moisture Problems evalewis Kitchen & Bath Remodeling 0 07-25-2012 05:26 AM
High moisture in slab, should I put down a barrier for travertine? help! eezeekial Tiling, ceramics, marble 15 11-21-2011 06:14 PM
Cleaning brush StevenH Painting 19 02-06-2011 12:13 AM
Basement Moisture, what's this? bergerdude Building & Construction 1 06-11-2010 02:27 PM
Moisture mystery in midst of shower redo Hisgirl Remodeling 3 01-05-2009 10:29 AM
