-   -   Moisture Barrier + Outside Support Beam ?'s (http://www.diychatroom.com/f2/moisture-barrier-outside-support-beam-s-175622/)
DukeLewis87 03-27-2013 01:02 AM
I have a house that i've been demoing for past month. Entire demo down to bare studs including plumbing/hvac/electrical. Its a 1300 sq ft house that has 400 sq ft of it on a concrete slab. The Other 900 sq ft is on a block foundation and sits 10" higher then the concrete slab portion.
----Moisture Barrier Question----
1. Build floor structure with 2"x6" Floor Joices for adequate room for HVAC and Plumbing to attached garage. (Which in return would make the step from 2 steps down to 1.)
2. Moisture Barrier??? Its one solid concrete slab with block foundation sitting ontop of slab. Im highly considering the spray foam insulation in my exterior walls. Not sure if that would count as a good moisture barrier between concrete slab and sub floor structure?
----Outside Support Beam----
The 400 Sq ft concrete slab add-on is between the attached garage and 900 sq ft block foundation portion. Well the concrete slab that meets the block foundation, there is a gap between the two. There was severe termite damage to the outside 2"x10"? outside plate.
As far as I can see the the block foundation has a 2"x4" sitting on top laying horizontal then the floor joices sit ontop of the 2"x4" with the 2"x10" sitting vertical toenailed into the floor joices as well as the 2"x4".
Width of viewable 2"x10" eaten would be about 10' to 12' with an overall of 26'
1) In order to replace that I would have to build a wall on the outside of the wall undernearth the roof trusses to support the roof before removing sections??
2) Do I have to support the floor joices from underneath in the craw space?
Any help would be appreciated. I can post pictures if needed.
Im trying to do this house right the first time.
joecaption 03-27-2013 01:06 AM
Post some pictures.
FYI There joist, not joices.
DukeLewis87 03-27-2013 01:13 AM
It will be tom afternoon. Ill have to take some pictures focused towards this location. But ill keep this open.
joecaption 03-27-2013 01:15 AM
Do us all a favor and go back and add your location to your profile.
Just go to Quick links to edit.
danpik 03-27-2013 06:57 AM
Originally Posted by joecaption (Post 1146731)
Post some pictures.
Wow dude...If we are going to start getting picky about spelling...:whistling2:
Windows on Wash 03-27-2013 08:49 AM
I think Joe's point about spelling is that it will help get more feedback on the project when everybody is on the same page.
Joe is not the spelling or grammar police by any stretch nor does he conduct himself as such.
He is just trying to get better feedback and a more concise answer for the poster. This only happens if the information on the front end (i.e. descriptions and details) are accurate.
:thumbsup:
DukeLewis87 03-27-2013 06:45 PM
6 Attachment(s)
Outside Support Beam Pictures. Pic 54,56,58.
Moisture Barrier Question Location Pictures. 49,52
First picture is a graphed to size diagram of the house. Per sq is 2sqft. Each number represents the picture number + direction of shot.
Between the 26' and 52' vertical is the concrete slab 2 dif level add-on.
House Picture 1 = 49#
House Picture 2 = 52#
House Picture 3 = 54#
House Picture 4 = 56#
House Picture 5 = 58#
House Picture 6 = 60#
House Picture 7 = 62#
House Picture 8 = 64#
House Picture 9 = 65#
House Picture 10 = 68#
House Picture 11 = 70#
DukeLewis87 03-27-2013 06:51 PM
6 Attachment(s)
Second Set #60,62,64,65,68,70
Picture #70.. Roof Joists are only sitting on top plate about 2". No overhang so gutters are mounted on the house just between the 36' to 52' vertical. I was thinking about building a wall directly on the backside of it to atleast have an overhang on the outside a little bit. As well to match the 26' to 36' vertical depth set.
Do you think I should proceed with this assumption? Kinda frightening knowing that roof joists are only sitting on top plate 2" if that..
DukeLewis87 03-27-2013 06:56 PM
1 Attachment(s)
This diagram is what type of floor plan im hoping for. Since theres going to be 2 bedrooms in the addon between orig house and garage I will need to supply heat runs out there. However as you can see its a concrete slab so thats why I suggested I should build a floor joist structure out of 2x6's to be able to run piping/hvac to that portion of the house.
Blue squares are representing queen size beds. Just an FYI.
Any input or anything would be much obliged.
