Modifying Insulated Fiberglass Door - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-03-2016, 08:21 AM   #1
Rewards Points: 790
modifying insulated fiberglass door
This is a door that leads out to the bulkhead cellar doors, which is not weather stripped. I want to replace existing wood/glass 1 3/8 door with fiberglass (will not rust), but the height is not full door height.
Can I cut fiberglass doors? Is it same as hollow core? If available, I'd just get a slab, cut from the top and keep the bottom weatherstripping/threshold. Thank you in advance.
carpdad is offline   Reply With Quote
Old 02-03-2016, 10:16 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,244
They have wood blocks in the top any bottom, but I think it would just be easier to order it pre-hung and custom sized.
The Following User Says Thank You to Windows on Wash For This Useful Post:
carpdad (02-06-2016)
Old 02-05-2016, 06:51 PM   #3
Rewards Points: 307
I did exactly this about one year ago, only I used a steel door rather than fiberglass (I looked for fiberglass, but had a really hard time finding a flush fiberglass door). In my case I cut it down to about 60" (don't remember the exact measurement). I cut it from the top as you indicate. The center was filled with styrofoam and I used an old chisel to create a channel to replace the wooden block on the top that I cut off. My door was prehung, and disabled and shortened the jambs and reassembled them. I was a little nervous about how it would work, but it all went very straightforwardly.
I looked into ordering one custom sized, and maybe I didn't know the right places to look, but I honestly would have built a door from scratch before paying the prices I was given. I suspect I could have gotten much more reasonable prices if I wanted a door closer to normal height.
LanterDan is offline   Reply With Quote
The Following User Says Thank You to LanterDan For This Useful Post:
Window popped out in traffic! Bigplanz Automotive Repairs 12 06-27-2015 06:35 PM
Painting a Prefinished Fiberglass Front Door sore thumb Painting 6 08-16-2013 10:36 PM
Fiberglass door, gel stain, and nervous breakdown wit's end Painting 8 10-26-2011 10:10 PM
Need to replace front door, existing door non-standard size uncle Windows and Doors 1 07-25-2011 06:50 AM
