Mobile Home Subfloor - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-14-2010, 10:32 PM   #1
Question
mobile home subfloor
I am installing slate flooring on areas of my home. The joists are 2x10 with 16" centers. Existing subfloor is 5/8 OSB. I will add 3/4" plywood. Will this be sufficient? Thnx
mrbig is offline   Reply With Quote
Old 10-14-2010, 11:08 PM   #2
Subfloor
That should be more than suffient except you will still need to lay down some hardi board in order for the put to adhere properly.
daniel.redd is offline   Reply With Quote
Old 10-15-2010, 11:35 AM   #3
Calculate your deflection first courtesy of the John Bridge forum: http://www.johnbridge.com/vbulletin/deflecto.pl. And see if the slate tile manufacturer has any further requirements. Good luck!
littlecleo is offline   Reply With Quote
Old 10-15-2010, 12:04 PM   #4
Rewards Points: 5,336
Slate(stone) requires a more dimensionally stable substrate then ceramic tile. I don't know how you would calculate the bounce rate going down the road.
Ron
Old 10-18-2010, 11:14 AM   #5
SteelToes's Avatar
Rewards Points: 150
Hey mrbig, my name is George and I work for a Chicago area Home Depot. In my opinion you are going to big with that CDX. I would recommend staggering 5/8 Durock cement board with some construction adhesive right over 5/8 OSB, unless there is damage on your existing subfloor. I think 5/8 cement board would be an ideal subfloor for the slate tiles, but plywood is just too much. Hope that helps.
I’m a Home Depot Store Associate, trained and authorized to help people on the Internet
What do you say we do a little clicking before we sand, or paint, or saw.
*Do not link to your store*
Moderator
SteelToes is offline   Reply With Quote
The Following User Says Thank You to SteelToes For This Useful Post:
Tangelo (10-25-2010)
Old 10-18-2010, 01:30 PM   #6
Im a Home Depot Store Associate, trained and authorized to help people on the Internet
What do you say we do a little clicking before we sand, or paint, or saw. Get the answers youre looking for at http://community.homedepot.com
That sure explains the advice given.
Ron
Old 10-18-2010, 07:52 PM   #7
Rewards Points: 276
This has got to be a joke right?
Jim F is offline   Reply With Quote
Old 10-18-2010, 09:03 PM   #8
jlhaslip's Avatar
Rewards Points: 1,502
Proper etiquitte dictates that Thou Shall Not Offend The Forum Admins.
Your invitation has been ignored at this location. A bit of discretion is in order...
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 10-20-2010, 11:19 PM   #9
Rewards Points: 150
Follow the advice given about the JohnBridge forum and you can't go wrong. I live in a newer mobile home and got lots of info and helf from the forum. Simply go to the forum and see what your deflection rating is to be safe.
MikeVila is offline   Reply With Quote
venting from mobile home through new metal roof jeanmoon Roofing/Siding 8 05-01-2015 08:53 AM
running electric under mobile home brianbrianj Electrical 8 10-26-2014 02:16 PM
mobile home related metal roof insulation chris313scorpio Building & Construction 0 09-28-2010 09:29 AM
putting mobile home on an old house foundation rkr1991 Building & Construction 3 08-19-2010 09:20 AM
Replacing Mobile Home Package AC Unit jack roscoe HVAC 3 05-24-2010 02:13 PM
