mobile home renovations
There is really no difference between renovating a mobile home and a regular home, just that sizes and materials are not standard. In other words, don't try to rplace doors or kitchen cabinets with over the counter replacements, they won't fit. Keep in mind also that there is a line that runs between the two halves and forget about plumbing the other side of the mobile. Heating ducting have to be extended with a large diameter connecting "snorkel" - mine is 12" in diameter and it is a ***** to replace.
On the bright side, everything is relatively easy to get at with a mobile. Hopefully you have easy access underneath. Make sure the skirting is in decent condition and vented. Check the foundation and make sure there isn't gaps between the top of the piers and the mobile frame.
There is a mobile home repair forum I have used.
Always remember, it ain't home till you take the wheels off!
