Mobile Home Door Knob Removal... - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-21-2010, 04:58 PM   #1
I live in a 10 year old double-wide trailer. Two of the bedrooms have dummy door handles, of which I was going to change out for locking handles. Problem is: door handle caps cannot be removed. they can be loosened but do not come off b/c of the door handle. i see screws but cannot get to them with-out cutting the caps off and ruining the old handles. are these handles ever supposed to be removed?
alexaa20 is offline   Reply With Quote
Old 10-21-2010, 05:12 PM   #2
the Musigician
DangerMouse's Avatar
There are a few different styles but they all remove.
Can you post a picture of your problem? That almost always helps here.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
alexaa20 (10-21-2010)
Old 10-21-2010, 05:30 PM   #3
okay, here is a picture showing the cap pulled back as far as it goes..... a screwdriver will not fit between....
Old 10-21-2010, 06:26 PM   #4
the Musigician
Not familiar with that style myself, but it looks like there are screws there. There may also be a 'release' tab holding the knob to the shaft that may be released using a flathead screwdriver.
DM
Old 10-21-2010, 10:53 PM   #5
" Euro " electrician
frenchelectrican's Avatar
I have see that style before and what you have to do is slide the plate back to oringal spot and look for very small indent tab and get slotted screwdriver and push the indent tab in and it will come out then you can able do the rest.
Merci.
Marc
Old 10-22-2010, 12:24 AM   #6
This pic shows how I get mine off. Yours look like they may be the same. Take that little set screw out and it slides right off.
Shane1 is offline   Reply With Quote
Tags
door , handle , knob , mobile home , trailer
running electric under mobile home brianbrianj Electrical 8 10-26-2014 02:16 PM
Replacing Mobile Home Package AC Unit jack roscoe HVAC 3 05-24-2010 02:13 PM
Mobile home with covered deck macboney Roofing/Siding 1 10-29-2009 09:21 PM
deck for a mobile home rln17 Building & Construction 2 09-09-2008 04:51 PM
Mobile home electric. RobertS Electrical 7 02-27-2008 12:25 PM
