Mixed Bag Of Tallents - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-04-2013, 06:02 AM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,452
Mixed Bag of Tallents
Stuck in a hotel out in the boonies of Texas....so killing some time while I have my morning coffee....no questions here....just posting up some pics of what I'm doing....
It's startup time on 3 autoclaves....I did the controls system design and programming...so now I'm managing the contractors doing the conduit install....before it's over I will have ran conduit..pulled wire...terminated...powered up....programmed...tested...with a little bit of welding along the way....and maybe some hydraulics....
This is the heating coil.....or, about 13,000 lbs of thick wall SS
It will be heated via a 24MBTU gas fired combustion system with ratio control on the air/fuel mixture....
And this is one of my control panels....for you PLC guys...CompactLogix....those boxes in lower corners are DAU's....the system has 200 thermocouples and 96 vacuum transducers....
And you guys just thought I made bad jokes, worked on my 2-story addition and threw people in jail.....
Old 11-04-2013, 06:08 AM   #2
DIY staff
Rewards Points: 7,174
That's a bunch of wires!
Trying to keep that straight inside of your head? Not easy----
Old 11-04-2013, 06:38 AM   #3
PoleCat's Avatar
Rewards Points: 1,646
I hadn't heard about the throwing people in jail thing. I have NO criticisms to offer.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 11-04-2013, 06:55 AM   #4
Rewards Points: 3,130
How, pray tell, is that little forklift moving a 13,000-lb coil?
Old 11-04-2013, 06:58 AM   #5
JOATMON
ddawg16's Avatar
That forklift is rated for right around 13k lbs. it was close
Old 11-04-2013, 07:36 AM   #6
joed's Avatar
Rewards Points: 12,392
What do they cook in those after they are complete?
Old 11-04-2013, 07:44 AM   #7
custom user
Rewards Points: 150
Whiskey.
JasperST is offline   Reply With Quote
Old 11-04-2013, 07:47 AM   #8
JOATMON
ddawg16's Avatar
Aircraft parts....aircraft like the B2 and 117 stealth fighter had their parts made in something similar. In this case, they will be used for wings...but I can't go into any more detail than that...sorry.
Old 11-04-2013, 08:15 AM   #9
PoleCat's Avatar
Carbon fiber UAV wings. Details are available from the Chinese.
Old 11-04-2013, 08:20 AM   #10
JOATMON
ddawg16's Avatar
Lol....who do you think makes them for the Chinese?
Mixed voltage gang and Canadian code (alberta specifically) BMcN Electrical 0 09-29-2013 11:13 AM
SLC: Mixed Feelings almazon Flooring 83 08-23-2013 09:08 AM
Stain mixed with concrete BigJim Concrete, Stone & Masonry 7 04-09-2013 08:51 PM
using recently mixed thinset with newly mixed thinset DiyCR fan Flooring 6 03-19-2013 08:19 AM
Paint mixed wrong marge 1 Painting 2 06-15-2010 09:41 AM
