Missing Program Button On Garage Door Opener - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-09-2013, 09:16 PM   #1
ifi
Missing program button on garage door opener
Hi,
Recently moved into to a new house and need to program the garage door opener but the program button is missing.
Any workaround?
Thanks!
Missing program button on garage door opener-img_20130609_161503.jpg   Missing program button on garage door opener-img_20130609_161525.jpg
ifi is offline   Reply With Quote
Old 06-09-2013, 09:37 PM   #2
Msradell's Avatar
Rewards Points: 128
Is it actually missing or is it just recessed so you have to use the tip of a pen or something like that to push it? Have you looked of the instruction manual for the opener for a clarification? I don't think it's a case here but some of the newer openers have the program button as part of the wall-mounted switch.
Msradell is offline   Reply With Quote
Old 06-09-2013, 10:12 PM   #3
ifi
It is an older unit and the wall switch doesn't have a program button. According to the instructions manual it is supposed to have a switch that could be pressed without using a pin.
Old 06-10-2013, 08:00 AM   #4
Rewards Points: 12
The program button is supposed to be in the top hole. It either broke off or was pulled out. As suggested a pen tip or pin will get you going.
Dan
djlandkpl is offline   Reply With Quote
In theory: expand attached garage, or add detached garage? hyunelan2 Building & Construction 5 11-09-2012 06:34 PM
MWBC to Garage Questions benleef Electrical 3 02-22-2012 12:02 PM
How to wire a detached Garage? (w/ Conduit?) FLintonRice Electrical 7 06-27-2011 02:08 PM
Replacing Button for Electrical Garage Door Opener FL_Deb Electrical 6 04-22-2008 12:36 PM
