-   -   Missing program button on garage door opener (http://www.diychatroom.com/f2/missing-program-button-garage-door-opener-181580/)
ifi 06-09-2013 09:16 PM
2 Attachment(s)
Hi,
Recently moved into to a new house and need to program the garage door opener but the program button is missing.
Any workaround?
Thanks!
Msradell 06-09-2013 09:37 PM
Is it actually missing or is it just recessed so you have to use the tip of a pen or something like that to push it? Have you looked of the instruction manual for the opener for a clarification? I don't think it's a case here but some of the newer openers have the program button as part of the wall-mounted switch.
ifi 06-09-2013 10:12 PM
It is an older unit and the wall switch doesn't have a program button. According to the instructions manual it is supposed to have a switch that could be pressed without using a pin.
djlandkpl 06-10-2013 08:00 AM
The program button is supposed to be in the top hole. It either broke off or was pulled out. As suggested a pen tip or pin will get you going.
