Mismatch Tiles - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-25-2008, 07:26 PM   #1
Mismatch Tiles
all,
We have tile in kitchen and foyer in our home. We have carpet in living room, dining and study - all are on the same floor as kitchen and foyer.
We are planning to replace carpet with tile, but can not find the excat same tile as kitchen. Is it o.k to use slightly differnt tile and use small transition tiles, where both the mismatch tiles meet.
Will this affect resale of the house?
I would appreciate your response.
asdfgh is offline   Reply With Quote
Old 03-25-2008, 08:37 PM   #2
Rewards Points: 528
Yes, you can do it as you plan. But I question your want or need of installing tile in the living and dining rooms. When you plan to sell, buyer's will be expecting carpet or hardwood flooring and tile may be a turnoff. I think it depends also on how the house is designed and whether or not tile in these rooms will blend in. The tile also may feel cool underfoot as many people like to take off their shoes. I have vinyl tile in my kitchen and used two lengths of marble laid end to end as transition pieces between that and the dining room which has a carpet. Try to find a decorator forum for some ideas and also check with a real estate agent for popularity of your idea to buyers.
rjordan392 is offline   Reply With Quote
Old 03-26-2008, 08:57 PM   #3
Tile Contractor
Bill_Vincent's Avatar
I wish I took pictures!! I just did a house last week where I did almost exactly what you're talking about, but the different tiles met at the doorway between the kitchen and mudroom. In the Kitchen, I used a 13x13 diagonal, and in the mudroom a square set 12x12. What I did as a transition was to do a band across the doorway of diamonds and triangles the same as shown in the pic below, and it worked fine:
"Whether you think you can, or you think you can't, You're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline   Reply With Quote
Will vinyl tiles stick to this? rebekkah Flooring 1 01-12-2008 02:04 AM
How do you Lay Large Tiles over Plywood Subfloor? 1655graff Flooring 20 10-01-2007 06:28 PM
TrafficMaster grout f.y.i. denman Flooring 16 07-01-2007 04:07 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 08:43 PM
Vinyl Tiles over pre-existing layers Thwiipp Flooring 1 09-05-2006 02:10 PM
