Mirror Installation Help - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-29-2010, 02:03 PM   #1
Mirror installation help
I need to install a 32"x39" bathroom vanity mirror. It is going to be framed with a 1x12" marble pencil. I would prefer to not use clips but want to make sure the mirror is installed safely and won't come off the wall! I'd also like whatever adhesive to be "green". Any suggestions here?
sbmarcovsky is offline   Reply With Quote
Old 05-29-2010, 02:36 PM   #2
Rewards Points: 5,336
They sell something called mirror adhesive that will keep the mirror secured to the wall. Since the mirrors weight will be supported by the frame, that's all you should need.
Do a search for, "green" mirror adhesives if that's what you want.
Ron
Old 06-01-2010, 12:20 AM   #3
cocobolo's Avatar
Rewards Points: 5,788
About 5 years ago I had a very large mirror - about 48" x 72" delivered and had the delivery folks install it on a remodel job I was doing.
All they did was to put several large globs of silicone on the wall (drywall - primered) and push the mirror in place. They held it for about 5 minutes.
It is behind a marble tiled tub surround, so the area gets moist. It's still there, no problems.
No doubt the frame you are going to use will be fine.
cocobolo is online now   Reply With Quote
